ASUS RT-AX57 Go Firmware version 3.0.0.6.102_57206 – 2026/10/07)  ASUS RT-AX57 Go Firmware version 3.0.0.6.102_57206 2026/10/07   This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX57 Go Firmware version 3.0.0.6.102_57206 – 2026/10/07)  ASUS RT-AX57 Go Firmware version 3.0.0.6.102_57206 2026/10/07   This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update...
RELEASE
  • #44189
    • Replies 8,737
    2026/10/07
    [Service Announcement] Adjustment to the Speedtest Feature on ASUS Networking Products
    Security Fixes:
    • Web management interface: Strengthened data handling for the connected device list and added stricter content checks when importing configuration profiles.
    • Network speed test service: Added allowlist validation for service command parameters, so that only expected values are accepted.
    • System protection service: Adjusted address parameter validation and event logging, strengthening access control between local services.
    • Certificate import process: Adjusted file handling and password passing, with stricter parameter validation.
    • Third-party account authorization: Narrowed the recipients of authorization data to better protect authorization information.
    • Web management interface: Adjusted the output handling of feedback content.
    • Notification service: Added identity verification for local connection sources and tightened the related file permission settings.
    • Mobile device connection authorization: Added a device matching check to strengthen the access token issuance process.
    • Device discovery service: Removed a non-essential internal function endpoint to strengthen overall access control.
    • AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.
    • System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
    • Network diagnostic data query: Strengthened value range checks for time interval parameters.
    • Network diagnostic data query: Added allowlist validation for query fields.
    • Internal data query: Improved field matching logic and optimized the memory release process under error conditions.
    • Time synchronization settings: Strengthened parameter validation for the server name.
    • File upload handling: Fixed an issue where certain input formats could cause the web management service to become unresponsive.
    • Wireless channel selection tool: Adjusted the handling of command parameters to prevent unintended command execution.
    • Certificate upload: Added a pre-check of archive contents to prevent files from being written to unintended locations.
    • System configuration file generation: Strengthened parameter content checks to prevent abnormal configuration values from affecting network service settings.
    • VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax57-go/helpdesk_bios?model2Name=RT-AX57-Go
