› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AC68U – Official Thread Good to see ASUS still supporting the ASUS RT-AC68U with a new Firmware version release 3.0.0.4.386.51255 Version 3.0.0.4.386.51255 Date: 2023/03/02 1.Fixed HTTP response splitting vulnerability. 2.Fixed Samba related vulerabilities. 3.Fixed...
- This topic has 8 replies, 2 voices, and was last updated 5 months, 2 weeks ago by
March 3, 2023 at 5:54 pm #22932
Date: 2023/03/02
3.Fixed cfg server security issues.
4.Fixed Open redirect vulnerability.
5.Fixed token authentication security issues.
6.Fixed security issues on the status page.
7.Fixed XSS vulnerability.
8.Fixed CVE-2022-26376
9.Fixed CVE-2018-1160
10.Fixed IPv6-related bugs.
11.Added a new login URL http://www.asusrouter.com to fixed the login issues.
12.Optimize the AiMesh web interface
13.Fixed network map UI bugs
14.Fixed bugs related to Wi-Fi calling.
15.Supported web history record exported.
16.Fixed IPSec VPN server compatibility with Windows 10 VPN client.
17.Improved AiMesh connection stability.
18.Fixed IPTV issues.You need to login in order to vote
May 13, 2023 at 2:50 pm #24460New ASUS RT-AC68U Firmware version 3.0.0.4.386.51665
Version 3.0.0.4.386.51665
Date: 2023/05/11
-Fixed the issue where Traffic Analyzer sometimes couldn’t record data.Security updates:
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.You need to login in order to vote
December 1, 2023 at 8:33 am #28281Great to see ASUS still supporting the RT-AC68U with this latest ASUS RT-AC68U Firmware version 3.0.0.4.386_51668
Version 3.0.0.4.386_51668
2023/11/30
1. Resolved an issue causing excessive log generation due to bwdpi issue.
2. Fixed a potential issue causing higher CPU utilization.https://www.asus.com/uk/supportonly/rt-ac68u/helpdesk_bios/
March 20, 2024 at 5:26 pm #31454RT-AC68U is EOL now – RIP !
All variants of it have ended last summer already.
https://www.asus.com/event/network/eol-product/
This reply was modified 2 years, 7 months ago by
Grisu.
Grisu.
March 20, 2024 at 5:49 pm #31457That is good to know but a real shame as the RT-AC68U is a legend, this also means the DSL-AC68U is also EOL
November 28, 2024 at 7:21 am #34991Nice to see ASUS are still providing improvements to the RT-AC68U even though it is EoL.
New ASUS RT-AC68U Firmware version 3.0.0.4.386_51722
Version 3.0.0.4.386_51722
2024/11/26
Resolved issues with customized icon functionality.
March 13, 2025 at 12:00 pm #35968Another firmware release for the ASUS RT-AC68U.
ASUS RT-AC68U Firmware version 3.0.0.4.386_51733
2025/03/10
4. Enhance system access control mechanisms.https://www.asus.com/uk/supportonly/rt-ac68u/helpdesk_bios/
August 20, 2025 at 12:36 pm #39299So even though the ASUS RT-AC68U is EOL, ASUS are still releasing firmware updates …
ASUS RT-AC68U Firmware version 3.0.0.4.386_52048
Version 3.0.0.4.386_52048
2025/08/19
Security Enhancements:
– Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.You need to login in order to vote
May 12, 2026 at 2:09 pm #42684Another EoL release – ASUS RT-AC68U Firmware version 3.0.0.4.386_521022026/05/12This model was end of its life, and its firmware, utility, website, and manual will no longer be updated. For more details, please refer to https://www.asus.com/event/network/eol-product/Security Fixes
– Enhanced DNS name handling to address a potential memory issue that could occur in rare cases during name format conversion, improving system security and robustness.
– Improved safeguards for execution modules to reduce the risk of substitution during certain processes.You need to login in order to vote
