- This topic has 1,420 replies, 25 voices, and was last updated 1 week, 6 days ago by
robgbc.
January 3, 2026 at 4:10 pm #41248May 16, 2026 at 8:38 pm #42710
ASUS ZenWiFi XT8 Firmware version 3.0.0.4.388_24814
2026/05/15
Security Fixes:
– Enhanced DNS name handling to address a potential memory issue that could occur in rare cases during name format conversion, improving system security and robustness.
– Improved safeguards for execution modules to reduce the risk of substitution during certain processes.You need to login in order to vote
August 6, 2026 at 2:38 pm #43134ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.388_24854
2026/08/04
Security Fixes
– Strengthened verification when a software component downloads – external resources, improving connection security.
– Improved data-display handling in a web function to enhance browsing security.
– Strengthened data handling in the system logging function.You need to login in order to vote
August 6, 2026 at 2:49 pm #43135Manually updated to 3.0.0.4.388_24854 & all good.
I continue to run my XT8s in AP mesh mode behind a UniFi Cloud Gateway Fiber and the XT8s are still working so well that it’s hard to justify replacing them.
August 6, 2026 at 3:28 pm #43136Great to know and absolutely, if its working well and suits your needs, keep going with you current setup
Only slight concern is at some point the XT8 will reach EoL, more of a challenge for early 2027
August 6, 2026 at 10:43 pm #43142August 7, 2026 at 6:37 am #43145October 23, 2026 at 9:24 am #44555ASUS ZenWiFi AX (XT8) Firmware version 3.0.0.4.388_24911
Version 3.0.0.4.388_2491150.02 MB2026/10/22This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update to continue using it.
Please refer to Speedtest Service Announcement for details.
https://www.asus.com/support/faq/1057454/Supports Surfshark VPN account login for a smoother user experience. (Supported model only)
Fixed an issue that could cause DNS resolution failures and loss of Internet access when DNSSEC is enabled.
Security Fixes
VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.-
This reply was modified 2 weeks, 2 days ago by
dodgydrains.
dodgydrains.
dodgydrains.
October 23, 2026 at 9:33 am #44559October 23, 2026 at 4:02 pm #44561“Fixed an issue that could cause DNS resolution failures and loss of Internet access when DNSSEC is enabled.”
This exact issue bit me within a day of the Internet-wide DNSSEC root key rollover, which occurred on October 11. The temporary fix was to disable DNSSEC on the router, but if this firmware update is solid I will re-enable DNSSEC.
Anxiously awaiting to hear how this update goes for others.
October 26, 2026 at 12:41 am #44578Credit to Asus, they’ve dropped 3 updates this year for the almost 7 year old ZenWiFi XT8 system and although I’ve had mine in AP mode behind a newer router, first Mikrotik & then Unifi, for the past few years, the wifi and wireless backhaul are still rock solid.
