› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX3000– Official Thread New ASUS RT-AX3000 Firmware version 3.0.0.4.388.22237 Version 3.0.0.4.388.22237 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart...
- This topic has 5 replies, 2 voices, and was last updated 1 year, 5 months ago by
January 14, 2023 at 2:55 pm #22403
7. Fixed USB icon issue in port status.
8. Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
9. Fixed status page HTML vulnerability. Thanks to David Ward.
10. Fixed CVE-2018-1160. Thanks to Steven Sroba.
11. Fixed cfg_server security issue.You need to login in order to vote
May 31, 2023 at 4:06 pm #24909New ASUS RT-AX3000 Firmware version 3.0.0.4.388.23403
Version 3.0.0.4.388.23403
Release Date: 2023/05/31
New features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN-iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
-Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
-Modified the USB application option text in dual WAN.
-Allowed WireGuard Server clients to access the Samba server.
-Fixed memory leak issue.
-Enabled the failback function when using the iOS/Android USB backup WAN.
-Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh nodeSecurity updates:
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.You need to login in order to vote
June 23, 2023 at 9:24 pm #25287New ASUS RT-AX3000 Firmware version 3.0.0.4.388.23556
Version 3.0.0.4.388.23556
Release Date: 2023/06/20
Bug Fixes and Enhancements
– NowTV profile has been added under new IPTV profiles.
– IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
– Fixed a GUI bug that occurred when adding port range rules in the Network Service Filter.
– Resolved an issue that caused hostname errors in the DDNS service.Security Fixes
– Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
– Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
– Corrected an OpenVPN vulnerability categorized as CWE-134.
– Fixed the Hostap vulnerability CVE-2019-10064.
– Patched a command injection vulnerability to improve overall security.
– Strengthened protection against SSH brute force attacks.You need to login in order to vote
September 28, 2023 at 7:34 am #27154New ASUS RT-AX3000 Firmware version 3.0.0.4.388_23925
Version 3.0.0.4.388_23925
2023/09/27
Bug fixes and function modifications:
-Fixed v6plus-Related Issues and Added OCN Support.
-Resolved OpenVPN Server TAP Mode Issue.
-Fixed the problem that the Aicloud app cannot add router on Android 9.Security updates:
-Corrected an OpenVPN vulnerability categorized as CWE-134.
-Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319You need to login in order to vote
October 5, 2024 at 2:17 am #34269ASUS RT-AX3000 Firmware version 3.0.0.4.388_25127
Version 3.0.0.4.388_25127
94.99 MB
2024/09/301. Optimized memory management mechanisms, improving system efficiency and stability.
5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.Please unzip the firmware file, and then verify the checksum.
SHA256: 693651ab7d180163095a1ef530d2c1f0929d9d977e9215920678537217a3c016You need to login in order to vote
May 23, 2025 at 3:35 pm #37848ASUS RT-AX3000 Firmware version 3.0.0.4.388_25210
2025/5/19
- Optimized the app’s remote access capabilities for a smoother and more reliable connection.
Improved compatibility with certain IoT devices.
