ASUS RT-BE92U – Official Thread New RT-BE92U Firmware 3.0.0.6_102_37025 Firmware 3.0.0.6_102_37025 11/05/2024 – Release note – Bug Fixes and Enhancements: 1. Optimized memory management mechanisms, improving system efficiency and stability. 2. Strengthened input validation and…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-BE92U – Official Thread New RT-BE92U Firmware 3.0.0.6_102_37025 Firmware 3.0.0.6_102_37025 11/05/2024 – Release note – Bug Fixes and Enhancements: 1. Optimized memory management mechanisms, improving system efficiency and stability. 2. Strengthened input validation and...
Viewing 7 posts - 16 through 22 (of 22 total)
  • #42937
    • Replies 8,738
    This week, I reconfigured my ASUS RT-BE92U router to better handle my growing collection of smart home gear, including a robotic lawnmower, smart door cameras, a robotic hoover, and security cameras etc. It’s great to see that ASUS’s built-in ‘IoT Network’ feature automatically creates a dedicated VLAN (ID 52) out of the box, making robust network isolation and security separation incredibly easy to deploy
    Good to see this work in practice.
    #42952
    • Replies 148
    This is a useful feature. I did the same to isolate iot gear like ring doorbell etc. Dont trust them as they dont get software updates often if at all
    #42954
    • Replies 8,738
    Very useful, I didn’t mention this earlier as I also enabled the option to place the IoT network on the 192.168.52.0/24 subnet and turned on AP Isolation, ensuring that devices on the IoT network can’t communicate with one another. Combined with the dedicated VLAN, it gives each device its own almost sandboxed environment, which is ideal for limiting lateral movement and keeping less‑trusted IoT gear properly contained.
    Sounds good in theory at least, now it’s just down to the firmware staying consistent with the isolation rules.
    #43096
    • Replies 8,738
    ASUS RT-BE92U Firmware version 3.0.0.6.102_40311
    Release: 2026/07/29
    New Features:
    – LED Lighting Scheduler: Added scheduling support for LED.
    – New Time Zone Options: Added “Vancouver, Whitehorse (PST7)” and “Edmonton, Yellowknife (MST6)” time zone options for Canada.
    – Added QoE feature to dynamically optimize network traffic for a smoother online experience.
    – Improved MAC address display logic on the WDS (wireless bridge) page, fixing cases where the band name and its MAC address were shown incorrectly.
    – Fixed an issue where Client List sorting could stop working under certain conditions, and removed a duplicate wired device card in the “By Interface” view.
    – Optimized the IPv6 address design for Networks.
    – Improved handling of unstable network cables.
    – Improved stability during the AiMesh node setup process.
    – Improved the reconnection process for IPv6 Plus (Japan) after a reboot or disconnect.
    – Improved IPv6 Option handling, including network connectivity after a reboot – following a direct firmware upgrade in certain scenarios.
    – Fixed an issue where a physical LAN port could disappear after the setup process when – using the automatic WAN type detection mechanism.
    – Improved AP Isolation synchronization for Networks profiles that don’t use a dedicated subnet.
    – Strengthened firewall rule configuration for UPnP, improving port-forwarding stability and firewall rule restoration reliability.
    – Fixed an issue where the URL-forwarding utility could become unresponsive after an internal network component update.
    Security Fixes:
    – Strengthened verification when a software component downloads external resources, improving connection security.
    – Improved data-display handling in a web function to enhance browsing security.
    – Strengthened data handling in the system logging function.
    We recommend upgrading to this version to maintain optimal protection.
    https://www.asus.com/uk/networking-iot-servers/wifi-7/all-series/asus-rt-be92u/helpdesk_bios?model2Name=ASUS-RT-BE92U
    #43300
    • Replies 8,738
    Logged into my RT-BE92U this morning and its alerting me that a new ASUSWRT-Merlin firmware – 3006.102.8_4 is available.
    Currently I’m running 3006.102.8 and ill have to see these new Fixes have any benefit to myself as currently happy with 3006.102.8.
    Changlog: 3006.102.8_4
    `3006.102.8_4 (20-Aug-2026)
    - UPDATED: OpenVPN to 2.7.6.
    - UPDATED: miniupnpd to 2.3.11.
    - CHANGED: When downgrading an OVPN server from TLS Encrypt V2
               mode to tls auth mode, the V2 key will be replaced
               with an appropriate V1 key.
    - CHANGED: IPv6 address provided as second argumnet to ddns-start
               script (aligns with 3004.388)
    - FIXED: Cannot connect to gaming servers if a game forwards
             a port through UPnP (3006.102.8 regression)
    - FIXED: A couple of potential security issues in httpd and
             ipsec cert handling
    - FIXED: netstat-nat would return an empty list if no option
             is selected on the Netool webui interface`
    #44409
    • Replies 8,738
    ASUS RT-BE92U Firmware Version 3.0.0.6.102_40497
    2026/10/12
    Security Fixes:
    AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
    AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
    AiCloud: Strengthened authentication and path validation for remote file access.
    VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
    #45033
    Avatarvitt13
    • Replies 46
    Sorry, maybe it’s wrong thread, but I have a question regarding backup settings, is it possible to apply settings from ASUS RT-BE92U to RT-BE88U and vice versa like in all Fritz Boxes where all settings compatible (Wi-Fi, security and so on)?
