ASUS RT-BE88U – Official Thread ASUS RT-BE88U WiFi 7 Dual-Band Router Promotion Link https://press.asus.com/news/asus-unveils-rt-be88u-wifi-7-dual-band-router/ —- Initial firmware release ASUS RT-BE88U Firmware version 3.0.0.6.102_33911 Version 3.0.0.6.102_33911 2024/03/26 Initial firmware release     https://www.asus.com/uk/supportonly/rt-be88u/helpdesk_bios/
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-BE88U – Official Thread ASUS RT-BE88U WiFi 7 Dual-Band Router Promotion Link https://press.asus.com/news/asus-unveils-rt-be88u-wifi-7-dual-band-router/ —- Initial firmware release ASUS RT-BE88U Firmware version 3.0.0.6.102_33911 Version 3.0.0.6.102_33911 2024/03/26 Initial firmware release     https://www.asus.com/uk/supportonly/rt-be88u/helpdesk_bios/
  • #31686
    • Replies 8,726
    2024/03/26
    • Initial firmware release
    #34409
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS RT-BE88U Firmware version 3.0.0.6.102_33928 (2024/10/09)
    Version 3.0.0.6.102_33928
    63.58 MB
    2024/10/09
    1.Optimized memory management mechanisms, improving system efficiency and stability.
    2.Strengthened input validation and data processing workflows, further protecting your information security.
    3.Improved web rendering engine, enhancing browsing experience and security.
    4.Enhanced security of system command processing to guard against potential malicious operations.
    5.Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    Please unzip the firmware file, and then verify the checksum
    SHA:472c984062d8e2ce2be4efebf3d69d14bb69b35ec21c346ac9a05135eaedfb5d
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-be88u/helpdesk_bios?model2Name=RT-BE88U
    #34984
    • Replies 8,726
    New ASUS RT-BE88U Firmware version 3.0.0.6.102_37094
    Version 3.0.0.6.102_37094
    2024/11/25
    New features:
    – New “Network” page to consolidate main network and Guest Network Pro for simplified management.
    – Supported MLO (Multi-Link Operation) backhaul.
    *Currently, MLO backhaul can only be formed with the same model.
    Bug Fixes and Enhancements:
    #36168
    • Replies 8,726
    ASUS RT-BE88U Firmware version 3.0.0.6.102_37963
    2025/03/20
    4. Enhance system access control mechanisms.
    #37319
    • Replies 8,726
    ASUS RT-BE88U Firmware version 3.0.0.6.102_38151
    2025/04/23
    New Features:
    1. Added support for Jumbo Frame. This setting can be found under “LAN > Switch Control”.
    1. Implemented a security patch to address an OpenVPN issue.
    2. Improved compatibility with IoT devices on WPA2/WPA3 networks.
    3. Enhanced the stability of remote connections.
    4. Resolved an issue with the WiFi scheduler.
    5. Improved Parental Control scheduling with support for SDN clients.
    6. Fixed an issue causing Movistar IPTV to malfunction.
    #37828
    • Replies 8,726
    ASUS RT-BE88U Firmware version 3.0.0.6.102_38152
    2025/05/19
    • Improved system efficiency and stability.
    • Strengthened input validation and data processing workflows to further enhance security of system.
    #39016
    • Replies 8,726
    ASUS RT-BE88U Firmware version 3.0.0.6_102_38186
    2025/08/08
    Security Enhancements:
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
    – SFP+ Port IPTV Support – Added IPTV configuration support on the SFP+ port
    #42179
    • Replies 8,726
    Latest ASUS RT-BE88U Firmware version 3.0.0.6_102_39254
    2026/03/16
    Improvements:
    – Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
    – Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    – Refined accessibility-related UI and interaction details.
    – Improved overall remote connection stability.
    – Improved system behavior when using System Diagnostic on feedback page.
    Bug Fixes:
    – Fixed incorrect connection status display for certain Wi-Fi devices.
    – Fixed a system issue that caused AiCloud features to appear on unsupported models.
    – Strengthened input sanitization mechanism
    – Enhanced system API validation for stronger protection consistency.
    – Strengthened command handling and system resource access controls.
    – Improved system logging and security event recording mechanisms.
    #42680
    • Replies 8,726
    ASUS RT-BE88U Firmware version 3.0.0.6.102_39256
    2026/05/07
    Security Fixes:
    – Enhanced system security by addressing an unsafe remote script execution mechanism in.
    – Improved system security by addressing a heap buffer overflow vulnerability during cache handling.
    #44170
    • Replies 8,726
    ASUS RT-BE88U Firmware version 3.0.0.6.102_39450
    2026/10/07
    – Supports Surfshark VPN account login for a smoother user experience. (Supported model only)
    Security Fixes:
    – Web management interface: Strengthened data handling for the connected device list and added stricter content checks when importing configuration profiles.
    – Network speed test service: Added allowlist validation for service command parameters, so that only expected values are accepted.
    – AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
    – AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
    – AiCloud: Strengthened authentication and path validation for remote file access.
    – System protection service: Adjusted address parameter validation and event logging, strengthening access control between local services.
    – Certificate import process: Adjusted file handling and password passing, with stricter parameter validation.
    – Third-party account authorization: Narrowed the recipients of authorization data to better protect authorization information.
    – Web management interface: Adjusted the output handling of feedback content.
    – Notification service: Added identity verification for local connection sources and tightened the related file permission settings.
    – Mobile device connection authorization: Added a device matching check to strengthen the access token issuance process.
    – Device discovery service: Removed a non-essential internal function endpoint to strengthen overall access control.
    – AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.
    – System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
    – Network diagnostic data query: Strengthened value range checks for time interval parameters.
    – Network diagnostic data query: Added allowlist validation for query fields.
    – Internal data query: Improved field matching logic and optimized the memory release process under error conditions.
    – Time synchronization settings: Strengthened parameter validation for the server name.
    – File upload handling: Fixed an issue where certain input formats could cause the web management service to become unresponsive.
    – Wireless channel selection tool: Adjusted the handling of command parameters to prevent unintended command execution.
    – Certificate upload: Added a pre-check of archive contents to prevent files from being written to unintended locations.
    – System configuration file generation: Strengthened parameter content checks to prevent abnormal configuration values from affecting network service settings.
    – VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
