ASUS ZenWiFi Pro XT12 – Official Thread ASUS ZenWiFi Pro XT12 Hardware Specs: CPU1: Broadcom BCM4912 (2.0 GHz, 4 cores) FLA: 256 MiB RAM: 1 GiB WI1 chip1: Broadcom BCM6715 WI2 chip1: Broadcom BCM6715 ETH chip1: Broadcom BCM4912 Switch: Broadcom BCM4912
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi Pro XT12 – Official Thread ASUS ZenWiFi Pro XT12 Hardware Specs: CPU1: Broadcom BCM4912 (2.0 GHz, 4 cores) FLA: 256 MiB RAM: 1 GiB WI1 chip1: Broadcom BCM6715 WI2 chip1: Broadcom BCM6715 ETH chip1: Broadcom BCM4912 Switch: Broadcom BCM4912
Viewing 15 posts - 1 through 15 (of 16 total)
  • #20817
    • Replies 8,738
    • CPU1: Broadcom BCM4912 (2.0 GHz, 4 cores)
    • FLA: 256 MiB
    • RAM: 1 GiB
    • WI1 chip1: Broadcom BCM6715
    • WI2 chip1: Broadcom BCM6715
    • ETH chip1: Broadcom BCM4912
    • Switch: Broadcom BCM4912
    #20821
    • Replies 8,738
    ASUS ZenWiFi Pro XT12 latest firmware
    Version 3.0.0.4.386.49723 (UKTH)
    2022/08/04
    ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.4.386.49723
    1. Supported U-NII-4 5.9GHz channels(US only) for reducing interference and improving connection speed.
    2. Fixed AiMesh backhaul issue.
    3. Fixed Wake-on-LAN issue.
    4. Improved system stability.
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWIFI_XT12/FW_ZENWIFI_XT12_300438649723.zip
    #21403
    • Replies 8,738
    New ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.4.388.21293
    Release Date: 2022/10/24
    1. Supported WireGuard VPN server and client.
    7. Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    8. Fixed status page HTML vulnerability. Thanks to David Ward.
    9. Fixed CVE-2018-1160. Thanks to Steven Sroba.
    10. Fixed cfg_server security issue
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWIFI_XT12/FW_ZENWIFI_XT12_300438821293.zip
    #21693
    • Replies 8,738
    So I have been made aware that for the ZenWIFI Pro XT12 Firmware version 3.0.0.4.388.21293, a couple of features are not working/missing.
    • No Wireguard client, only server.
    •  VPN Fusion issues
    • UI related issues
    I have spoken with ASUS and they plan to release another firmware shortly, but I am unsure yet as to whether this will be a beta firmware release or more formal via ASUS download servers
    Either way, hopefully this will help those that have contacted myself
    #21760
    • Replies 8,738
    New Firmware Version 3.0.0.4.388.21678
    2022/11/21
    ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.4.388.21678
    1. Optimized memory usage and improved system stability.
    2. Fixed 2.5G port compatibility issues.
    3. Added a new web GUI login URL http://www.asusrouter.com
    4. Fixed IPTV compatibility issue with Movistar.
    5. Fixed VPN fusion, AiMesh, and Network map GUI bugs.
    6. Fixed WAN compatibility issue with Starlink router.
    7. Fixed miniupnpc vulnerabilities, CVE-2015-603, CVE-2017-1000494
    8. Fixed IPSec server vulnerability, CVE-2022-40617
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-pro-xt12/helpdesk_download/
    #22282
    • Replies 8,738
    New Firmware version 3.0.0.4.388_22127
    – Release Note –
    Bug Fixes and Enhancements:
    1. Improved system stability.
    2. Fixed the IPsec VPN compatibility issue with Win10.
    3. Fixed the VPN fusion user interface issues under the HTTPS connection.
    4. Fixed Client DOM Stored XSS vulnerability.
    5. Improved Wireguard performance.
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWIFI_XT12/FW_ZENWIFI_XT12_300438822127.zip
    #23282
    • Replies 634
    ASUS ZenWiFi Pro XT12 Firmware version 9.0.0.6.102.4856
    Version 9.0.0.6.102.4856
    Beta Version
    49.55 MB
    2023/03/21
    Be noted: This is an early stage beta, there might be bugs. This version can be downgraded via web GUI only.
    1. Recap new features of 3.0.0.6.102: Guest network Pro(SDN), VLAN, Auto USB WAN backup, iPhone tethering, Multi-services WAN.
    2. Re-defined VLAN, supports Trunk, Access mode with VLAN-only-network.
    3. Synchronize Guest network pro (SDN) with VLAN, create/delete new VLAN-only-network will create/delete a new profile in Guest network as well.
    4. Port isolation and AP isolation to restrict device access to each other.
    5. Re-defined multi-service WAN, disable it by default.
    6. Add surfshark VPN in VPN fusion.
    MD5: 67edce1962927cbbc18deee86477b725
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWIFI_XT12/FW_ZenWiFi_XT12_90061024856.zip?model=zenwifi%20pro%20xt12
    #23288
    • Replies 8,738
    According to a SNB forums post, ‘Traffic analyzer is working again with this beta firmware release’
    #27846
    • Replies 8,738
    Latest ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.4.388_24177
    Version 3.0.0.4.388_24177
    2023/11/01
    New features:
    -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    -DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    -Allowed WireGuard Server clients to access the Samba server.
    -Fixed memory leak issue.
    -Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
    -Ensured consistent display of client status on the WireGuard server.
    -Enhanced system stability when accessing the WireGuard Server with DMZ enabled.
    -Improved stability when enabling or disabling the WireGuard server.
    -Addressed an issue that prevented clients from accessing the network when setting up the OpenVPN server in TAP mode.
    -Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    -Corrected a bug encountered when adding a rule to the Network Services Filter.
    Security updates:
    -Fixed DoS vulnerabilities in firewall configuration pages.
    -Fixed DoS vulerabilities in httpd.
    -Fixed information disclosure vulnerability.
    -Fixed null pointer dereference vulnerabilities.
    -Fixed token authentication security issues.
    -Fixed security issues on the status page.
    -Fixed Client DOM Stored XSS.
    -Upgraded to the latest dropbear version.
    -Fixed a stack overflow vulnerability.
    https://www.asus.com/uk/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-pro-xt12/helpdesk_bios?model2Name=ASUS-ZenWiFi-Pro-XT12
    #32790
    • Replies 8,738
    New ASUS ZenWIFI XT12 Firmware version 3.0.0.6.102_35186
    Version 3.0.0.6.102_35186
    2024/07/12
    [ New features ]
    -Kid’s Network: Easily create a separate SSID for children’s devices. Integrated AdGuard DNS offers advanced protection options, including service and website blocking, query logs, tracker blocking, and ad pop-up Ad blocking. (More details: https://www.asus.com/support/faq/1053541)
    -VPN Network: Establish a VPN-specific SSID to centralize VPN settings for all connected devices. This feature allows for the importation of profiles from popular VPN services such as Surfshark, NordVPN, and CyberGhost from VPN Fusion.(More details:https://www.asus.com/support/faq/1053542)
    -AdGuard: AdGuard offers ad-blocking and privacy protection features. Simply apply it in the router or Smart Home Master profile to filtering out advertising, tracking, and malware domains at the DNS level, preventing your device from loading potentially harmful content. In network level. (More details:https://www.asus.com/ca-en/support/faq/1051213)
    [ New VPN services in VPN Fusion ]
    NordVPN:https://www.asus.com/support/FAQ/1051215
    CyberShost: https://www.asus.com/support/FAQ/1051645
    [ Bug Fixes and Enhancements ]
    -Stability enhancements.
    [ Security update ]
    -OpenVPN config security enhancement in cusomization option.
    -USN applicationn security improvement for XSS attacks.
    https://www.asus.com/uk/supportonly/zenwifi%20pro%20xt12/helpdesk_bios/
    #33531
    • Replies 8,738
    New ASUS ZenWIFI XT12 Pro Firmware version 3.0.0.6.102_35188
    Version 3.0.0.6.102_35188
    2024/08/29
    Fixed injection vulnerability.
    #34855
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.6.102_35199
    Version 3.0.0.6.102_35199
    50.08 MB
    2024/11/13
    SHA256: 9966a50a4c00af2d666ef3a1225b8e5edfcf93466e466f0aed907e3a140ad969
    https://www.asus.com/ie/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-pro-xt12/helpdesk_bios?model2Name=ASUS-ZenWiFi-Pro-XT12
    #39350
    • Replies 8,738
    ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.6.102_35254
    2025/08/26
    Security Enhancements:
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
    #42092
    • Replies 8,738
    New ASUS ZenWIFI Pro XT12 Firmware version 3.0.0.6.102_36697
    2026/03/12
    Improvements:
    Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
    Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    Refined accessibility-related UI and interaction details.
    Improved overall remote connection stability.
    Improved system behavior when using System diagnostic on feedback page.
    Bug Fixes:
    Fixed incorrect connection status display for certain Wi-Fi devices.
    Fixed AiMesh nodes not displayed correctly in the device list.
    Fixed a disconnection issue that occurred after enabling the MAC Filter.
    Strengthened input sanitization mechanism.
    Enhanced system API validation for stronger protection consistency.
    Strengthened command handling and system resource access controls.
    Improved system logging and security event recording mechanisms.
    #43133
    • Replies 8,738
    ASUS ZenWiFi Pro XT12 Firmware version 3.0.0.6.102_37485
    2026/08/06
    Security Fixes
    – Strengthened verification when a software component downloads – external resources, improving connection security.
    – Improved data-display handling in a web function to enhance browsing security.
    – Strengthened data handling in the system logging function.
    We recommend upgrading to this version to maintain optimal protection.
