› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi Pro XT12 – Official Thread
- This topic has 15 replies, 3 voices, and was last updated 1 minute ago by
- October 20, 2026 at 5:35 pm #44526
ASUS ZenWiFi Pro XT12 Firmware version 3.0.0.6.102_37544
2026/10/20
Fixed an issue that could cause DNS resolution failures and loss of Internet access when DNSSEC is enabled.Security Fixes
VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.We recommend updating to this version to maintain optimal protection.
