› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Asuswrt-Merlin 386.5 – ZenWiFi AX (XT8) https://www.snbforums.com/threads/asuswrt-merlin-386-5-gnutons-builds-are-now-available.78160/ Any ideas what the difference between this and RMerlin might be?
- This topic has 27 replies, 3 voices, and was last updated 4 years, 4 months ago by
April 5, 2022 at 7:19 am #18558
Changing from default could mean you miss other important messages that may happen, especially if the error is fixed in the next firmware refresh.
If you wish to change logging level,
Try:
Default message log level: – Leave as is (Notice, I believe is default)
Log any messages more urgent than: – change to ‘Error or Critical’ (not sure which one will remove offending log entries) ?
https://en.wikipedia.org/wiki/Syslog#Severity_level
Note: if that does not work, then trial and error I am afraid
April 5, 2022 at 7:46 pm #18563Or ask GNUton in SNB forum why you get his logs and if he knows about it and how to solve or fix in next release.
April 5, 2022 at 9:30 pm #18565Or ask GNUton in SNB forum why you get his logs and if he knows about it and how to solve or fix in next release.
I asked in the thread in SNB forum and didn’t get a response yet
April 6, 2022 at 6:44 pm #18575Made several Teams calls and did not encounter any issues that I could see.
Looks like the following are known issues with Asuswrt-Merlin:
- Nodes need to be added to AiMesh using ethernet cable
- LED lights are on even when off in settings (toggling on and off seems to have fixed this for me)
- PHY rate showing as 0 Mbps
- kernel: protocol 0000 is buggy, dev archer – Others have also confirmed that this repeatedly in the logs. ‘Fix’ is to change log level to ‘Info’
April 6, 2022 at 6:49 pm #18576April 6, 2022 at 7:02 pm #18577So it seems to be more a cosmetic issue than a real problem.
Yeap, only cosmetic only so far. I will keep this for now, until I get bored.
April 7, 2022 at 7:12 am #18580Had any Teams calls yet ?
April 7, 2022 at 6:56 pm #18604No issues with Teams calls so far. I will have a few longer meetings tomorrow and will keep monitoring.
April 7, 2022 at 7:15 pm #18606No issues with Teams calls so far. I will have a few longer meetings tomorrow and will keep monitoring.
Great news
April 8, 2022 at 11:08 pm #18618Had small issues with Teams call hanging today for a second or so before resuming. Beta 46980 was definitely more stable, I will keep this one for a little longer and may revert back to beta 46980.
April 9, 2022 at 6:00 am #18619That is a shame, but good to know also
BTW – did you double check your QoS settings was the same as previously with ASUSWRT firmware ?
April 9, 2022 at 9:49 am #18623I do not change anything under QoS. It is always left on default.
April 9, 2022 at 10:52 am #18624I do not change anything under QoS. It is always left on default.
I cannot find an example, but I know sometimes ASUSWRT-Merlin builds may have slightly different default configuration settings to that of ASUSWRT.
