› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Asuswrt-Merlin 386.5 – ZenWiFi AX (XT8) https://www.snbforums.com/threads/asuswrt-merlin-386-5-gnutons-builds-are-now-available.78160/ Any ideas what the difference between this and RMerlin might be?
- This topic has 27 replies, 3 voices, and was last updated 4 years, 6 months ago by
- April 3, 2022 at 1:09 pm #18526
April 3, 2022 at 2:03 pm #18527April 3, 2022 at 2:25 pm #18528Did you ever see Merlin fw for models GNUton is supporting?
To be honest, I have never owned a device that was supported by either.
April 3, 2022 at 2:38 pm #18529(Content removed by Admin)
They both are just “better” AsusWRT (and Gnuton uses Merlin-code for mostly DSL and other models).
April 3, 2022 at 3:30 pm #18530@GNUton uses ASUSWRT-Merlin and overlays this to work with ASUS DSL models, it now seems he is expanding to include all the feature of ASUSWRT-Merlin for use on XT8 etc.
The builds should be more secure and upto date etc with many new features above that offered by stock ASUS firmware.
If @GNUton adds extra features to his builds, he tends to use the term ‘unleashed’ but as far as I am aware, it is ASUSWRT-Merlin through and through on new hardware ;)
https://gnuton.github.io/asuswrt-merlin.ng/
April 3, 2022 at 4:48 pm #18532I have updated all 4 XT8 to this now and will see how it goes. The first bit of nuisance is that all nodes had to be added using ethernet cable. Also, the LED lights seem to turn back on with changes to settings. Toggling on and off turns it off again. Under Network, it doesn’t show the PHY rate.
April 3, 2022 at 5:09 pm #18536You are brave ;)
Did you factory reset after upgrade ?
April 3, 2022 at 5:29 pm #18538Yes I did factory reset. Sent some feedback on the original thread. Let’s see…..
April 3, 2022 at 5:42 pm #18541Any Teams calls tomorrow do you have ?
April 3, 2022 at 5:52 pm #18543April 3, 2022 at 5:53 pm #18544Keep us updated
April 4, 2022 at 8:54 pm #18553How was your the first day running the new @GNUton build for your XT8 ?
April 4, 2022 at 9:06 pm #18554No problems to report apart from getting the following in the logs:
Apr 4 22:04:16 kernel: protocol 0000 is buggy, dev archer
Apr 4 22:04:27 kernel: protocol 0000 is buggy, dev archer
Apr 4 22:04:28 kernel: protocol 0000 is buggy, dev archer
Apr 4 22:04:29 kernel: protocol 0000 is buggy, dev archer
Apr 4 22:04:31 kernel: protocol 0000 is buggy, dev archer
Apr 4 22:04:33 kernel: protocol 0000 is buggy, dev archer
Apr 4 22:04:34 kernel: protocol 0000 is buggy, dev archerGoes on and on and on…….
April 5, 2022 at 5:55 am #18556ASUSWRT-Merlin firmware has the option to adjust the logging levels as types, so maybe worth playing around as I am sure this is ported into the @GNUton builds also ?
Are you using any Guest Wifi ?
April 5, 2022 at 6:45 am #18557I am not using Guest WiFi as I did not set one up.
There is following available under log settings:
Default message log level
Log any messages more urgent than
What should I chose for each?
