› UKTH forums › 🛜 Wireless Routers & Modems › AVM & Wireless › AVM Fritz!Box 6850 5G – Official Thread AVM Fritz!Box 6850 5G – Hardware Specs CPU: Dakota @ 717 MHz – ARM Cortex A9 – CPU-Cores: 4 RAM Size: 512 MB Flash Size: 512 MB Ethernet Port Count: 4 x 1GbE-LAN Technical specifications: Integrated...
- This topic has 12 replies, 3 voices, and was last updated 2 years, 11 months ago by
January 17, 2023 at 8:58 am #22433
RAM Size: 512 MB
Flash Size: 512 MB
Ethernet Port Count: 4 x 1GbE-LANTechnical specifications:
- Integrated 5G mobile broadband modem (mini-SIM)
- IP-based telephony
- 4 x gigabit LAN ports
- Wireless access point compliant with IEEE 802.11ac, n, g, a
- 1 x USB 3.0 port for printers and storage media
- Integrated DECT base station for up to six cordless telephones
- 1 a/b port (either TAE or RJ11) for an analog telephone, answering machine or fax
Wi-Fi:
- Wi-Fi 5 (up to 866 Mbit/s gross, 5 GHz) and 4 (up to 400 Mbit/s gross, 2.4 GHz)
- Secure upon delivery with WPA2 encryption, WPA3/2 transition mode is also available
January 17, 2023 at 9:01 am #22434Latest FRITZ!Box 6850 5G firmware FRITZ!OS 7.30
Release date: 03/02/2022
Download:
http://ftp.avm.de/fritzbox/fritzbox-6850-5g/other/fritz.os/
**Top functions of FRITZ!OS**
————————————————————– Priority for working from home – Easy to enable prioritization of a computer for internet access
– Improved SMS function – Send function for SMS and Journal for received and sent SMS
– FRITZ!Fon displays weather forecast on the start screen (currently only available for germany)
– FRITZ! Smart Home now supports DECT compatible roller shutters
– Smart Home: Lightsequence “Wakeup/Sleep” for FRITZ!DECT 500 and compatible DECT LEDs
– Smart Home: TOP – Perfect indoor climate with FRITZ!DECT 440 – humidity information at a glance
– For FRITZ!Box’s integrated fax machine: Log of received and sent faxes
– Telephony: TOP – Many improvements to user interface for using the telephone book, call diversion and call blocks————————————————————
With each FRITZ!OS update, AVM also updates its security functions. Therefore we recommend performing the update for all devices.
Note: Instructions for configuring and using Mesh functions are presented at en.avm.de/mesh-faq
Below you find a complete list and descriptions of the new functions in the latest FRITZ!OS, along with a list of further improvements in this version.
http://ftp.avm.de/fritzbox/fritzbox-6850-5g/other/fritz.os/info_en.txt
January 17, 2023 at 11:05 am #22436Latest Fritz!Lab beta-firmware: https://en.avm.de/fritz-lab/fresh-from-development/fresh-from-development/
https://en.avm.de/fileadmin/user_upload/DE/Labor/Download/fritzbox-6850_5g-labor-101876.zip
Download information:
Language: Multi-language
Version: 7.39-101876
Date: 7 December 2022You need to login in order to vote
January 17, 2023 at 5:59 pm #22448January 17, 2023 at 6:44 pm #22449January 17, 2023 at 7:20 pm #22450No, but manuals are very good and detailed.
September 17, 2023 at 3:50 pm #26983Hello! First post to this forum!
Does anyone have experience or ideas on how to connect an external antenna(s) on this device?
My idea is to boost the 5G (wire will go outside of the house) and also to be able to use the WLAN network. WLAN signal levels are not that important to me as I’m also using an extender for outdoors.
If I connect 4G dipole antenna (weather proof outdoor model), does it strengthen or weaken the 5G signal?
September 17, 2023 at 4:06 pm #26986Often loss on cables is greater than antenna gain (depending on length and quality compared to antenna gain).
Better to position router directly behind window on the right side and use a repeater (with LAN backhaul) for your home.
September 17, 2023 at 6:33 pm #26987Most AVM Fritz!box’s do support a Mesh type conductivity, “FritzBox or mesh repeater”. cannot recall if this can also support wired backhaul, but an option maybe ?
The 4G dipole antenna will not increase or decrease 5G wireless strength, but should enable better connection to a mobile network giving you a faster, more reliable connection.
https://en.avm.de/products/fritzbox/fritzbox-6850-5g/
September 17, 2023 at 8:35 pm #26992All AVM Fritz!Repeaters may be used in AVM-Mesh.
Only small ones directly plugged in to mains wont have a LAN-Port to be connected as backhaul (they may be uses as WLAN-repeater only).
All others may be used with LAN conntection to another AVM router (Fritz!Box) or Fritz!Repeater and have 2 LAN ports (one to master and another to a client or repeater again).Fritz!Boxes may be used as repeater as well.
They all allow LAN-backhaul and some of them even WLAN-backhaul, see the list below.
So they are ideal to get a second live if you have an unused old one (Fritz!OS 7 is needed to support AVM-mesh).https://en.avm.de/faqs/which-fritz-products-support-mesh/
September 17, 2023 at 8:55 pm #26998They all allow LAN-backhaul and some of them even WLAN-backhaul, see the list below.
October 1, 2023 at 3:57 pm #27203Often loss on cables is greater than antenna gain (depending on length and quality compared to antenna gain).
I acknowledge these things. It’s a good point that there comes signal loss especially with a long cable. This Fritz!Box replaced a Huawei B818-263 4G which failed to keep the 4G up without the same Outdoor antenna. And with the antenna the speed was still horrible. That Huawei was piece of sh!%. It’s the worst 4G modem I’ve ever installed to anyone. I hear it being good for those who actually have a strong signal out there.
The only place for the modem router is behing a huge balcony. It’s there where there is ethernet socket to route the Network/Internet to two floors under. To those floors the WLAN signal is really weak with any device from the top floor how ever the antennas are positioned.
Yes, good points. That’s how I was thinking it could be.
October 1, 2023 at 7:41 pm #27207let us know how it goes if you do decide to try the 6850 5G as it would be good information for others reading this forum
