Bosch Dishwasher Fault Code Generic Error codes for a Bosch dishwasher (as a guide)   • Error E12:      Limescale build up. Find more about it here. • Error E14:      Flow…
› UKTH forums › 📺 White & Brown Goods › DishWashers › Bosch Dishwasher Fault Code Generic Error codes for a Bosch dishwasher (as a guide)   • Error E12:      Limescale build up. Find more about it here. • Error E14:      Flow...
  • #11863
    • Replies 8,720
    • Error E14:      Flow meter failure. Find more about it here.
    • Error E15:      Water in the base trough. Find more about it here.
    • Error E16 & E17: Water filling the system. Find more about it here.
    • Error E18:      Water flow into the dishwasher. Find more about it here.
    • Error E22:      Filter is blocked. Find more about it here.
    • Error E23:      Issue with waste water pump. Find more about it here.
    • Error E24:      Dishwasher not draining. Find more about it here.
    • Error E25:      Waste water pump blocked, drain issue, filter clogged or pump impeller is jammed. Find more about it here.
    #11864
    • Replies 8,720
    and
    All codes E01, E02, E03, E04 and E05 all indicate a power module failure.
    E06: –     Door Switch
    E07: –     Dryer fan faulty
