› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › BT g.fast with dsl88u Hi I’ve scoured the net and read various forums to get g.fast working with this but I dont seem to be getting anywhere. When i got it out of the...
- This topic has 32 replies, 6 voices, and was last updated 7 years ago by
- August 29, 2019 at 3:59 pm #4054
Dont know but maybe due to necessarily routing for VLAN and bridge mode wont do any routing.
September 11, 2019 at 10:00 pm #4338I am not sure if this is any help but I have BT G-Fast working with this Router.
I have Wifi turned off and Unifi access points doing the Wifi so should be similar to the Google system.
Here are settings. Only issue I have is that if it disconnects it requires a reeboot to get going again hence my other post asking for Telnet firmware have a 4g Modem on my Network as well
PPPoE
Enable Wan Yes
Enable upnp Yes
802.1q Yes
VLAN ID 101
Wan Ip Auto Yes
PPP username bthomehub@btbroadband.com
Password bt
Disconnect 0
MTU 1492
Internet connection PPP Echo
Interval 6
Max Failures 10
<hr />
Admin DSL Setting
Modulation G.fast
Annex A
SRA Enabled
Bitswap Enabled
VDSL Profile 17a
G.Inp Enabled
G Vector Enabled
Stability Adjustment Disabled
Hope that is of some use
September 12, 2019 at 7:32 am #4369This is most useful, how are you finding G.fast are the speeds as expected
UK Sentinel
