› UKTH forums › Life & Stuff › Cars › Fiesta ST driver Side Front Window Auto-up not working So Fiesta ST180 (ST-2) 2015 returned from the garage after some major work and strangely the driver side front window auto-up was not working. (Battery was probable unplugged at some...
- This topic has 4 replies, 2 voices, and was last updated 4 years, 1 month ago by
October 7, 2022 at 3:39 pm #21154
(Battery was probable unplugged at some point)
Looking online lots of opinions to fix this and for us, the following worked to correct the Fiesta ST driver side window auto-up not working.
- Turn Ignition On (push start button once)
- Ensure all windows and doors are closed.
- Using window control button, roll driver side window a little more than halfway down and then wait a second
- Then using window control button, roll the window all the way up and keep holding the window button On for a further two seconds.
- This then should have reset the sensors etc. so window will now auto-up with a single press of driver side window button.
Note: I did have to do this a couple times to make it work
October 7, 2022 at 5:59 pm #21155This works for other cars too, my Skoda does it the same way.
You dont even have go down, just when it is up press as long till motor is turning off.Have to do it often, as there is a bad contact in the wireing near door angle (broken wire), so when opening door it probably loose contact and have to be reseted next time driving.
Not worth to repair.
October 7, 2022 at 7:29 pm #21156[quote quote=21155]Have to do it often, as there is a bad contact in the wireing near door angle (broken wire), so when opening door it probably loose contact and have to be reseted next time driving.[/quote]
Does sound like a contact or earth type issue, Cars and all there qwerks are fun, sometimes
October 8, 2022 at 11:47 am #21158Only broken wires where they are moved when opening the door – closed there is enough contact for function.
It is like this since years, so not worth further actions.You need to login in order to vote
October 8, 2022 at 12:06 pm #21159[quote quote=21158]It is like this since years, so not worth further actions.[/quote]
