AVM FRITZ!Box 3490 – Official Thread Today AVM have released the latest firmware for the beloved Fritz!Box 3490 ( FRITZ!OS 7.12) The update file “FRITZ.Box_3490.xx.xx.image” on http://ftp.avm.de contains the latest FRITZ!OS (Firmware) for the FRITZ!Box 3490. Attention:…
› UKTH forums › Wireless Routers & Modems › AVM & Wireless › AVM FRITZ!Box 3490 – Official Thread Today AVM have released the latest firmware for the beloved Fritz!Box 3490 ( FRITZ!OS 7.12) The update file “FRITZ.Box_3490.xx.xx.image” on http://ftp.avm.de contains the latest FRITZ!OS (Firmware) for the FRITZ!Box 3490. Attention:...
Viewing 8 posts - 16 through 23 (of 23 total)
  • #27284
    • Replies 8,748
    So just checked and yes on the Fritz!box 3490, LAN1 can be used as an ethernet WAN port.
    So as long as you either connect the 3490 to the ONT or the fibre Modem/router that can support bridge mode, then your vpn feature should work as normal, via LAN 1.
    Alas if your FTTH connection is 1Gb, then the 3490 may struggle with this speed for VPN and wifi etc.
    There is the The FB 5530 which is a dedicated fibre modem/router if you are feeling brave
    https://en.avm.de/products/fritzbox/fritzbox-5530-fiber/
    #27285
    Avatarmash47
    • Replies 4
    Thanks to you both.
    I’ll stick with the 3490. The VPN is more important to me than speed. 100mbps is enough.
    #27287
    Better to use an ONT (from provider) and an own router, could be a 4060 or 7590(ax) if you need more speed.
    Here (in Austria) the fibre models wont work on PON, as providers may use special configs on net and user side, so you have to stick on their ONT.
    #27289
    • Replies 8,748
    On mash47 said
    Thanks to you both.
    If/When you do get FTTH, let us know how it goes with the 3490 and your VPN
    #27290
    Avatarmash47
    • Replies 4
    My ISP, Zen, will only be using City Fibre or Openreach networks so it make take a while as City Fibre have no plans installing fibre in my area!
    #27291
    • Replies 8,748
    That is unfortunate.
    #27292
    Avatarmash47
    • Replies 4
    The MS3 network will be here soon but then I’d have to find another isp as good as Zen
    #27294
    • Replies 8,748
    ZEN do have a reputation for being good, but it does cost, Sky rate well from what I have seen over the years.
