› UKTH forums › Wireless Routers & Modems › AVM & Wireless › AVM FRITZ!Box 3490 – Official Thread Today AVM have released the latest firmware for the beloved Fritz!Box 3490 ( FRITZ!OS 7.12) The update file “FRITZ.Box_3490.xx.xx.image” on http://ftp.avm.de contains the latest FRITZ!OS (Firmware) for the FRITZ!Box 3490. Attention:...
- This topic has 22 replies, 3 voices, and was last updated 3 years, 1 month ago by
August 9, 2019 at 9:10 pm #3765
Attention: This update file is only intended for use with FRITZ!Box 3490! Please follow the instructions at the end of this file to install the update.
Product: FRITZ!Box 3490
Version: FRITZ!OS 7.12
Language: English, French, German, Italian, Spanish, Polish
Release date: 09.08.2019
– Over 50 new features and improvements: more performance and convenience in the wireless network, Mesh and Smart Home
– Seamlessly connected in the Mesh: Mesh WiFi steering, shared telephone book and Smart Home
– Well informed: Important information arrives simply and directly at the email address of your MyFRITZ! account
– New in the internet: more information on DSL, faster LTE and expanded VPN functions
– Practical to operate: quick overview of updates for FRITZ! products, LEDs can be switched off
– Stronger support for new products: FRITZ!Repeater 3000————————————————————
Note: Instructions for configuring and using Mesh functions are presented at en.avm.de/mesh-faq
Below you find a complete list and descriptions of the new functions in the latest FRITZ!OS, along with a list of further improvements in this version.
### Additional improvements in FRITZ!OS 07.12
#### DSL:
– **Improved** Certain information adapted on DSL pages
– **Improved** 35b interoperability to certain Broadcom remote sites improved#### Internet:
– **Fixed** Sporadic change of shared ports in rare cases
– **Improved** Increased stability#### WLAN:
– **Fixed** Time display for scan of wireless environment (5-GHz band) corrected#### Mesh:
– **Fixed** Mesh WiFi steering for devices on the wireless guest access improved
– **Improved** Stablity#### DECT/FRITZ!FON:
– **Fixed** PIN query came despite disabled PIN#### Home network:
– **Fixed** Powerline information of a FRITZ!Powerline device connected with the FRITZ!Box via LAN were missing in the “Device Details” area#### System:
– **Improved** Stability
– **Improved** Browser compatibility optimized for saving table renderings locally
– **Fixed** Push Service could not be disabled
– **Fixed** Push Service for saving settings deleted the sender settings
– **Fixed** During assignment of VPN rights for the current user, under certain circumstances this user’s other rights were removed
– **Fixed** Update in progress on FRITZ!Repeaters was displayed for too long in the “Mesh Overview”https://en.avm.de/nc/service/downloads/?product=fritzbox-3490
August 10, 2019 at 9:51 am #3774So I installed Fritz!OS 07.12 on my lovely Fritz!Box 3490 and all seems to be working as expected,
I ran the GRC ‘Sheilds Up’ port scan and as usual they (AVM) are still Leaving port 113 CLOSED rather than in STEALTH.
This is the only area of Fritz!Box OS I dislike, I understand that leaving port 113 is deemed ok given these are consumer products…..
August 10, 2019 at 1:05 pm #3783OMG! So far this morning my Fritz!Box 3490 has been a real nightmare, resynch with Cab multiple times, reduced my line synch from 55 / 10 (capped) to 45 / 0.20 yes 0.2. – finally got it back t0 normal by plugging in my DrayTeK 130 modem. then plugged back in Fritz!Box 3490 and DSL disconnects happen every 15 – 20 mins.
Either the new Fritz!OS 07.12 is broken or I had a bad firmware download – either way, it is not a good start .
Edit: So this afternoon I factory reset router and rebuilt from scratch, during my testing I noticed issues with IPv6 and so left the Fritz!Box 3490 on IPv4 this afternoon and all seemed to be stable, tonight I have switched on IPv6 (dual stack) and so far all working as expected, I can only assume (hope) as I am with BT, they may have had issues with their IPv6 distribution (servers) in my area and hence my initial problems?
Either way, what a fun day (not) ;-)
August 12, 2019 at 10:54 am #3800Again this morning, my Fritz!Box 3490 with IPv^ is having real issues, disconnects afer a synch and this is effecting up line synch speeds (upstream dropped from 10 Mbps to 0.4 Mbps
So have disabled IPv6 again this morning and all has resorted back to normal, either BT are still having IPv6 issues or the new firmware for the 3490 is not stable with the UK implementation of IPv6 ?
Either way, very odd this all is ……….
August 12, 2019 at 5:20 pm #3801Contact them as soon as it happens again!
They have good support and will ask you to mail them support data from your box and have a look whats going on.
You can get them out of the box, left down “Contents”, then left down “Fritz!Box Support” and choose “Generate Support Data”.
I still dont have IPv6 so I cannot tell anything about it but should come this year at my home.
Right now as first step they started IPv6 support for mobiles.
PS: There are reported many problems with IPv6 on Asus routers too ending with no connection, maybe ISPs still not uptodate with their settings or failure on both sides.
August 12, 2019 at 6:24 pm #3806Hi @Grisu, I have used the Fritz!Box 3490 with the previous firmware release and IPV6 worked very well, seems to be this new version causing me issues.
When I have used the feedback form previously, I usually get the AVM support agent (Michael Ellguth) and he is very ‘Yes or No’, not very helpful or imaginative ;-(
Shame really as my Fritz!Box 3490 has always been very good, I was hoping to see if issues was with my local (BT) settings or if other owners also have reported these issues before I raise a sport ticket with AVM.
Thanks for good advise ;-)
August 12, 2019 at 6:47 pm #3807Maybe not at all IPv6 related?
You can try using older DSL driver (Internet, DSL-Info, EmC or Noise Immunity, Use Previous DSL-driver).
August 12, 2019 at 9:30 pm #3811August 16, 2019 at 10:39 am #3831I tried the ‘Use Previous DSL-driver’ option and very simple procedure to follow, Fritz!Box has been stable for 2 days and IPv6 seems to be working as expected.
I plan to revert back to version 07.01 over the weekend as my synch has dropped from 55/10 to 44/5 and I have G.inp enabled in both directions, which I have never seen before on my line.
Thanks for advice ;-)
August 18, 2019 at 8:33 am #3868So I loaded Fritz!Box 3490 firmware version 07.01 yesterday and overnight the Fritz!Box re synched with exchange/dlsam/cab and all is back to how it was before, 55 Mbps Downstream and 10 Mbps Upstream (capped service).
All G.inp / Fastpath remains the same so it does appear from my limited testing that the latest Fritz!Box 3490 (07.12) has both IPv6 for UK /56 issues and certain DSL synch problems also .
Most unusual for AVM as they usually are very good ;-(
September 1, 2022 at 6:12 am #20668Sourced from AVM’s FTP site:
- Product: FRITZ!Box 3490
- Version: FRITZ!OS 7.30
- Language: English, French, German, Italian, Polish, Spanish
- Release date: 11/15/2021
# Top functions of FRITZ!OS
– Priority for working from home – Easy to enable prioritization of a computer for internet access
————————————————————# Additional improvements in FRITZ!OS 7.30
## Internet:
– **Improved** List of trusted certification authorities updated
– **Improved** When internet access to storage media via FTP/FTPS is enabled, the randomly preselected port number is displayed## USB:
– **Improved** compatibility with MacOS 12.0 “Monterey”
– **Improved** compatibility with several older devices (printers, scanners)You need to login in order to vote
February 2, 2023 at 6:06 pm #22628Just updated my Fritz!Box 3490 to FRITZ!OS 07.30, Splash Screen image for reference.
October 3, 2023 at 5:52 pm #27275Hi there, here’s my first post and it’s a question about the Fritz!Box 3490 …
Does this router retain the vpn feature when used on FTTH? This is an essential feature for me when away from home.
October 3, 2023 at 6:15 pm #27277The Fritz!box 3490 does not have a dedicated WAN port as it is a modem/router combo, but some Fritz!box models do support a WAN type connection via LAN1 port.
But the FTT service will provide either an ONT or an modem/router that converts the light in the fibre optic to a digital signal etc.
@Grisu is very knowledgeable, so hopefully he will see this post .I will have a look at mine later and see if this is possible and check VPN option also
October 3, 2023 at 7:23 pm #27280Why not?
I dont have a 3490, but seems to should work well.
VPN: https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-3490/3448_VPN-with-FRITZ/
As mentioned you will have to use LAN1 as WAN port.
