› UKTH forums › πΊ White & Brown Goods › Washing Machines › Hoover Candy Washing Machine Fault Codes Q. Yes, Candy group own Hoover . Candy Hoover Error codes (as a guide) An E01 error codeΒ (or on some models anΒ E07 error code) indicates an issue with the...
- This topic has 0 replies, 1 voice, and was last updated 5 years, 9 months ago by
February 6, 2021 at 2:55 pm #11858
An E01 error codeΒ (or on some models anΒ E07 error code) indicates an issue with the door lock. This could be an issue with the door lock itself, the wiring or the connection to the PCB board.
An E02 error codeΒ will indicate an issue with the fill. Now this either means that there is a trapped, blocked or pinched fill hose, or an issue with the water supply or with the valves.
An E03 error codeΒ indicates there was a problem with the drain circuit. This usually means there is something stuck in the pump.
An E04 error codeΒ may mean thereβs a problem with the anti flood, this means you have water in the base and may indicate that you have a leak.
An E05 error codeΒ means that you have an issue with the NTCΒ (the water temperature sensor at the back). It may be as simple as a loose connection which needs reconnecting.
An E06 error codeΒ is either a problem with the machine being out of balance if the error code is displayed straight after a spin or it’s a problem with the control boardΒ being faulty.
An E07 error codeΒ is either a problem with the door lock or with the motor being jammed and unable to spin.
An E08 error codeΒ indicates a problem with the motor speed sensor. This can result in the motor spinning up at very high speed for a few seconds before slowing down and then stopping. It may also mean that the motor is not spinning.
An E09 error codeΒ means that you have a problem with the motor triac on the circuit board. This may mean that you don’t have any motor drive.
An E10 error codeΒ on older machines may mean there’s a problem with the motorised selector. On new machines it could indicate a drum sensor issue if fitted.
Now error codes 11 through to 14 all relate to issues with washer dryers.
An E11 error codeΒ indicates there’s an open circuit on the dryer heater or a module issue. It’s a good idea to check the wiring from the sensor on the top the drum to the circuit board as this can become damaged during the spin cycle.
An E12 error codeΒ suggests a PCB communication error or an open circuit on the dryer heater sensor.
An E13 error codeΒ means that there is an issue with the PCB as doesΒ the E14 error code. This could also indicate an issue with the dryer heater or the NTC.
An E15 error codeΒ indicates that there may be an issue with the circuit board. It may not be programmed or the memory chip may have become corrupted.
An E16 error codeΒ means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but itβs hard to prove without the replacement of your heater.
An E17 error codeΒ means that there is an issue with the motor tachometer and could result in your motor not spinning.
An E18 error codeΒ means that there’s an issue with the PCB.
