iPhone 16 Pro “Squeeze” Effect When Pressing Side Buttons: Quirk or Feature?
› UKTH forums › 📱 Mobile › iPhones › iPhone 16 Pro “Squeeze” Effect When Pressing Side Buttons: Quirk or Feature?
  • #38859
    • Replies 8,718
    If you’ve noticed a subtle “indent” or screen distortion when pressing the Action, Volume, or Camera Control buttons on your iPhone 16 Pro, you’re not alone — and you’re not seeing things.
    With iOS 18, Apple introduced a new visual feedback mechanism that activates when side buttons are pressed. The left or right edge of the screen appears slightly compressed or darkened, creating the illusion of pressure affecting the display. While some early users feared it might be a hardware issue or display defect, it turns out to be intentional behavior baked into the OS.
    Apple designed this subtle animation to:
    • Confirm button activation through brief screen shading
    • Support the multifunction Action and Camera buttons
    • Enhance tactile awareness, especially for accessibility use cases
    Even older models like the iPhone 13 display similar effects after upgrading to iOS 18. Apple Support has referred to this as “normal performance.” At the moment, there’s no system toggle to disable this feedback, although it may eventually land in Accessibility settings if enough users request it.
    So, if you’ve seen this “squeeze” effect, rest assured — it’s not your screen flexing under pressure, it’s just another Apple handy feature.
