Sky ipv6 connection Hey guy’s anyone created ipv6 DNS connection? Am connected via Dns ipv4 via Google domain not through the Asus router though.just created the connection on single device, I have available…
UKTH forums 🛜 Wireless Routers & Modems 💬 ASUS & Wireless Sky ipv6 connection Hey guy’s anyone created ipv6 DNS connection? Am connected via Dns ipv4 via Google domain not through the Asus router though.just created the connection on single device, I have available...
Viewing 15 posts - 1 through 15 (of 39 total)
  • #29264
    AvatarKi11sh0t87
    • Replies 41
    Hey guy’s anyone created ipv6 DNS connection? Am connected via Dns ipv4 via Google domain not through the Asus router though.just created the connection on single device, I have available ipv6 through pass though but won’t connect when changed settings on DNS on device.wondering if it has to be static or 6to4 to connection first on Asus router? Any one had any luck?
    • Replies 8,229
    I forget, what ISP do you use as some ISP’s like Plusnet do not offer or allow IPv6
    #29266
    AvatarKi11sh0t87
    • Replies 41
    Sky pal
    AvatarKi11sh0t87
    • Replies 41
    Wan connection is automatic ip.and for ipv6 connections it says connect via pass through,but clearly doesn’t work double checked all the details and doesn’t allow it .so don’t know if keep the automatic IP the same and create a static ipv6 connection ?
    • Replies 8,229
    Sky supports IPv6 so that is a positive
    @dodgydrains
    uses Full-Fibre etc, so will be interesting if he is around later and which ISP he uses etc and any issues with IPv6
    #29269
    AvatarKi11sh0t87
    • Replies 41
    Cheers pal , hopefully <!–more–>He has an insight on the topic or anyone else..
    • Replies 610
    Attached is how I set up IPV6 on the XT8.
    I then go to https://test-ipv6.com/ to check if it worked.
    Not sure it this is the correct way or not, but seems to work for me.  I am with Hyperoptic.
    AvatarKi11sh0t87
    • Replies 41
    Looks good that pal ,I’ll test it when I get in nice one bud ,do you have to put that DNS code into the device aswel or just the router.is prefix still 24
    • Replies 610
    I only do this on the XT8, not on each device.
    I use Cloudflare IPV6 or Google IPV6
    Cloudflare:
    2606:4700:4700::1111
    2606:4700:4700::1001
    Google:
    2001:4860:4860::8888
    2001:4860:4860::8844
    AvatarKi11sh0t87
    • Replies 41
    Opens the pathway for DNS doesn’t on the router I’ll test weather it improves the individual device also, obviously only if that device is ipv6 compatible.cheers bud
    • Replies 8,229
    Thanks @dodgydrains
    #29285
    • Replies 8,229
    IPV6 Passthrough is a safe option and below is a general guide to help others with IPv6
    Generally, depending on your Internet Connection type:
    • If you have a PPPoE internet connection, you should select Native.
    • If you have a static IP internet connection, you should choose Static IPv6.
    • If you have an automatic IP internet connection, you should select Passthrough.
    Ref: https://www.digitalcitizen.life/ipv6
    #29287
    AvatarKi11sh0t87
    • Replies 41
    Yeh buddy doesn’t seem to work pass through way.
    AvatarKi11sh0t87
    • Replies 41
    Do I have to connect via native? That what it’s saying there.
    • Replies 8,229
    Try Native
