› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Sky ipv6 connection Hey guy’s anyone created ipv6 DNS connection? Am connected via Dns ipv4 via Google domain not through the Asus router though.just created the connection on single device, I have available...
- This topic has 38 replies, 3 voices, and was last updated 2 years, 8 months ago by
January 21, 2024 at 10:03 am #29322
It will work on both LAN (wired) and Wireless  clients
January 21, 2024 at 11:07 am #29323How do you know which is connected and what it’s using between ipv4 and ipv6
January 21, 2024 at 11:31 am #29324DNS Director does not use IP addresses to identify LAN/Wifi clients, it uses MAC Addresses.
https://en.wikipedia.org/wiki/MAC_address
January 21, 2024 at 11:38 am #29325Oh i I know pal ,am just wondering how it determines what connection to pick for the device ipv4 or ipv6 and if you can see on the device which one it is actually using at the time ?
January 21, 2024 at 12:40 pm #29327ASUS routers use a DUAL IP Stack, so unless you disable IPv4 (not advisable) then a device (will use both IPv4 and IPv6) and IPv6 is the traffic priority (usually) especially when connected to a Windows clients etc.
But some ISP’s and websites only support IPv4, so best to use both.
To check which clients are using what IP address, go to Advanced Settings > System Log > and the Tabs in that section give you DHCP / Wireless IP details etc.
January 21, 2024 at 12:45 pm #29328Cheers pal, that’s good to know think I’ve absorbed all the data I can the last few day’s,.. mind blow explosion ???? hhaa.thanks for your help.
January 21, 2024 at 12:50 pm #29329ASUS routers are fairly technical for a consumer grade device. This is why routers from say Netgear (and others) are sometimes better suited based on user skillset.
January 21, 2024 at 1:11 pm #29330January 21, 2024 at 1:23 pm #29331Haha.not anymore,keep that Netgear stuff haha.
