kernel: __ntfs_error: 58 callbacks suppressed error log message I had this problem and thought to share fix. The below errors in log relate to a USB storage device being plugged in, if you have either iTunes Server and/or…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless kernel: __ntfs_error: 58 callbacks suppressed error log message I had this problem and thought to share fix. The below errors in log relate to a USB storage device being plugged in, if you have either iTunes Server and/or...
  • #33077
    • Replies 8,674
    The below errors in log relate to a USB storage device being plugged in, if you have either iTunes Server and/or UPnP Media Server enabled, try disabling them to see if this helps remove the below error log messages being created multiple times
     kernel: tntfs error (device sda1, pid 2694): ntfs_lookup(): ntfs_iget(0x31be) failed with error code -2
