› UKTH forums › PC & Laptop Gaming › Other Stuff etc. › Laptop bot Booting Windows I recently wiped a laptop since I could not remember the password. It is a Dell Latitude 3400. the problem I am having, I get the following error message;...
- This topic has 9 replies, 3 voices, and was last updated 2 years, 1 month ago by
Grisu.
September 26, 2024 at 11:30 am #34158
Anonymous
- Replies 4
- New Here
Can anyone please advise as just clicking ok just does the same thing?
I can’t run command prompt or use the Bios settings, When I try get into the recovery using F1 It just does the same thing again and again.
Please see attached files.
September 26, 2024 at 12:21 pm #34160September 27, 2024 at 6:59 am #34185@deprima – have you tried pushing the F2 button repeatedly once your laptop has is starting up as this should be they way you enter the Dell Latitude 3400 BIOS. ?
Try: ‘as not sure which option may work’.
- At the Dell logo screen, press the F2 key several times until you enter the BIOS or System Setup.
- Alternatively, press the F12 key several times until you see the One Time Boot Menu and then select BIOS Setup or System Setup from the menu.
September 27, 2024 at 7:54 am #34186
Anonymous
- Replies 4
- New Here
I have tried this but am unable to alter the settings,
I have a Plan to wipe the hard drive and then load windowsYou need to login in order to vote
September 27, 2024 at 8:01 am #34187If that fails, take a look at the below video as they show how you can unlock BIOS passwords etc.
Note tried this myself but worth a try
September 27, 2024 at 8:38 am #34188
Anonymous
- Replies 4
- New Here
Thanks It is not the Password That I need, In the BIOS security, I am unable t alter anything
September 27, 2024 at 8:51 am #34189Do you know if your Dell laptop has a PSWD or CMOS jumper on its motherboard as this will remove all security around BIOS access ?
September 27, 2024 at 8:54 am #34190
Anonymous
- Replies 4
- New Here
September 27, 2024 at 10:24 am #34191Hopefully your plan to wipe the hard drive and then load windows will work
September 30, 2024 at 10:45 am #34231Lost my PC and have to buy new MB and power supply.
My Win-installation doesnt work anymore too, so I really have other problems right now.
Did you try to start the laptop with USB-Stick (you can make one with Windows download tool direclty from microsoft).
With it (manual installation) you can delete all partitions and newly install Win. HDD/SDD will be repartioned while doing so.If you only forgot your Win password there are much easier ways to create a new user and so you wont loose data.
