› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BT8 Whole Home Tri-Band Mesh WiFi 7 System – Official Thread I have just upgraded my ASUS AiMesh system from 3 x ET12 (with one ET12 as the main router) and 7 x XD4 to 6 x BT8 (with one BT8...
- This topic has 36 replies, 3 voices, and was last updated 1 month, 2 weeks ago by
August 27, 2026 at 6:46 am #43269
ASUS have come back and said for ASUS ZenWiFi BT8 Firmware version 3.0.0.6.102_58540 being removed…
Due to the stability issue of AiMesh Node, 3.0.0.6.102_58540 is removed
I believe both the BT8 and BT6 use the same Mediatek MT7988D SoC, hence probable why the BT6 latest firmware was also removed.
August 27, 2026 at 11:23 pm #43279Thanks for the quick reply. Should I roll back to the previous 58407 version? Is there a way I can update all 10 nodes at the same time rather than individually?
August 28, 2026 at 6:49 am #43281If your ASUS nodes consist of ZenWiFi BT8 and BT6 and you have not noticed any issues with connectivity or node stability or you have noticed all your IoT devices are now showing on your main network, then I would revert back to 58407.
Personally I would update your main AiMesh router first and then the Nodes individually, I do know others believe this should be the other way around, but each to their own.
Not sure on updating all nodes at the same time and hopefully somebody else can advise.
Upgrade All AiMesh nodes at the same time:
August 31, 2026 at 5:25 pm #43301Hi Skip, just loaded version 58542. Happy Bank Holiday (not here in Malta).
This reply was modified 2 months, 3 weeks ago by
Nick Holland.
August 31, 2026 at 6:34 pm #43303. Nick Holland Said:Hi Skip, just loaded version 58542. Happy Bank Holiday (not here in Malta).
Always embrace change and new technology. Never say “I can’t do that” instead say “I haven’t done that before, but I’ll give it a try”
Another new firmware release from ASUS for the ASUS ZenWiFi BT8, nice find
August 31, 2026 at 6:35 pm #43304ASUS ZenWiFi_BT8_Firmware Version 3.0.0.6.102_58542.2026/08/28.Bug Fixes and Enhancements:
Support LED scheduler capabilities.
Improved client list update flow and related UI responsiveness.
Improved configuration matching accuracy in specific scenarios.
Improved AiMesh stability.
Improved IPv6 connectivity stability in selected reboot/reconnect scenarios.
Fixed specific LAN/UPnP behavior issues after setup.Security Fixes:
Applied multiple security hardening updates across system components.
Improved input validation and request-handling protections in selected paths.
Included security fixes in affected services/modules (including bundled components).
Added defenses for memory-safety and injection-related risk patterns.We recommend upgrading to this version to maintain optimal protection.
October 2, 2026 at 3:27 pm #43834ASUS ZenWiFi BT8 Firmware version 3.0.0.6.102_58600
2026/10/01
Security Fixes:
AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
AiCloud: Strengthened authentication and path validation for remote file access.
VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.We recommend updating to this version to maintain optimal protection.
