My WAN IP address is not the same as external IP, why? I’m sorry for that I’m not very knowledgeable about these issues. Is there a negative impact on my connection?? such as ping vs online games. my modem wan ip 100.110……
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › My WAN IP address is not the same as external IP, why? I’m sorry for that I’m not very knowledgeable about these issues. Is there a negative impact on my connection?? such as ping vs online games. my modem wan ip 100.110…...
  • #3687
    Avatarlydoncon
    • Replies 1
    visible on website whatmyip.us
    I don’t use vpn and similar software…
    #3690
    • Replies 8,699
    The Answer will depend upon what ASUS router this is, is it a DSL or RT Router (I assume RT) If RT model than I can guess the WAN IP is that of your Modems IP +1.
    WAN IP = ISP modem/Gateway
    External IP = Actual Internet IP Address
    #3691
    AvatarSH
    • Replies 81
    your ISP have allocated you Carrier-grade NAT IP address ,  yes it can create issue like Strict NAT on gaming consoles , closed ports ,  tough to access computer or NAS from outside of network etc etc…..you can look your NAT type on your Gaming Device to know for sure ? …………………………..if you notice any issue you might need to ask your ISP to provide you Static WAN IPv4 address ………………….. if you don’t use services that needs dealing with ports etc … you will be fine
    lease time is set very low …usually lease time is set below 4Hr if there is some kind of maintenance going at back end………………….but i can be wrong
    #3723
    • Replies 1,032
    correct, its asking permanent for new leases, not good.
    By default it is set to 86400s (=24h), for special needs you can go down to 3600s (=1h) and you should better not go below this.
