NetDuma R2 Netduma Launches The New R2 Router and DumaOS 3 The R2 has been built for DumaOS 3.0 from day one and is available for pre-order now, including a launch discount for early…
› UKTH forums › 🛜 Wireless Routers & Modems › Alternative Router OEMs › NetDuma R2 Netduma Launches The New R2 Router and DumaOS 3 The R2 has been built for DumaOS 3.0 from day one and is available for pre-order now, including a launch discount for early...
  • #8891
    The R2 has been built for DumaOS 3.0 from day one and is available for pre-order now, including a launch discount for early orders. As our latest in-house router, we will be able to deploy the next wave of DumaOS features to the R2 first.
    The R2 will officially ship from August 6th.
    https://www.netduma.com/order/netduma-r2/
    NetDuma R2 Hardware Specs:
    CPU1: MediaTek MT7621AT (880 MHz, 2 cores)
    FLA1: ? MiB (Brand? Model?)
    RAM1: 256 MiB (Nanya NT5CB128M16FP-DI)
    Expansion IFs: none specified
    USB ports: 1
    WI1 chip1: MediaTek MT7603EN
    WI1 802dot11 protocols: bgn
    WI1 MIMO config: 2×2:2
    WI1 antenna connector: none
    WI2 chip1: MediaTek MT7612EN
    WI2 802dot11 protocols: an+ac
    WI2 MIMO config: 2×2:2
    WI2 antenna connector: U.FL
    ETH chip1: MediaTek MT7621AT
    Switch: MediaTek MT7621AT
    LAN speed: 1G
    LAN ports: 4
    WAN speed: 1G
    WAN ports: 1
    Default SSID: NetdumaR2
    Default IP address: 192.168.88.1
    the IP 192.168.88.1 is used by 37 additional devices
    of which 0 are Netduma devices
    Default login user: admin
    Default login password: password
    Source: https://deviwiki.com/wiki/Netduma_R2
    I have just asked on the Netduma forums if they plan to create an online emulator for there new R2 / DumaOS 3, so we can try before we buy
    Hopefully something for Netduma to consider
    #8919
    Alas it looks like Netduma will not be producing an DumaOS 3 emulator for us to all try
    https://forum.netduma.com/topic/31988-r2-dumaos-3-emulator/
