AVM FRITZ!Box 7590 AX – Official Thread Looks like AVM Fritz!Box are introducing a new and improved Wifi 6 Modem Router with the new FRITZ!Box 7590 AX . Technical Specifications Interfaces: Internet access with VDSL (including supervectoring)…
› UKTH forums › Wireless Routers & Modems › AVM & Wireless › AVM FRITZ!Box 7590 AX – Official Thread Looks like AVM Fritz!Box are introducing a new and improved Wifi 6 Modem Router with the new FRITZ!Box 7590 AX . Technical Specifications Interfaces: Internet access with VDSL (including supervectoring)...
Viewing 15 posts - 16 through 30 (of 31 total)
  • #32109
    • Replies 8,748
    Latest FRITZ!OS firmware version 7.80 is available for AVM FRITZ!Box 7590 AX
    Date: 30 January 2024
    New features:
    – Simplified configuration for connection to a fiber optic modem (ONT) – The speed of the Ethernet connection between LAN 1/WAN and the upstream device (e.g., fiber optic modem) is displayed on the overview page – further improvements and bugfixes
    DSL: – Improved Reworked DSL overview for FRITZ!Box – Improved ADSL2 interoperability problem let to connection disruptions for some remote sites.
    Wi-Fi: – Fixed Connection problems with the Nuki Smart Lock – Improved Problematic situations during operation of VR headsets Meta Quest 2/3 improved
    Telephony: – Fixed During an active parallel call, after a brief period the call was signaled only at the call destination – Fixed Termination of outgoing calls to certain mobile sites after two minutes – Improved Telephony more stable
    DECT/FRITZ!Fon: – Change Presets for the Deutschlandfunk web radio stations were updated
    System: – Improved Stability
    https://en.avm.de/fritz-lab/
    https://download.avm.de/fritzbox/fritzbox-7590-ax/other/fritz.os/
    #32115
    Latest for 7590 and 7590ax would be 7.90-Labor(beta), but still not visible on international (english) site.
    https://avm.de/fritz-labor/frisch-aus-der-entwicklung/frisch-aus-der-entwicklung/
    #32116
    • Replies 8,748
    Thank you, I published the FRITZ!OS firmware version 7.80 as some owners do not like using beta firmware, but good to know
    #32117
    Next release version will be OS 8.0.
    #32118
    • Replies 8,748
    Great news, is there an ETA for OS 8.0 ?
    #32119
    never ever, when they have finished it will be released.
    #32120
    • Replies 8,748
    • Replies 8,748
    Product: FRITZ!Box 7590 AX
    Version: FRITZ!OS 7.81
    Release date: 28/05/2024
    Firmware:
    https://download.avm.de/fritzbox/fritzbox-7590-ax/other/fritz.os/FRITZ.Box_7590_AX-07.81.image
    Release Notes
    **New features:**
    - Simplified configuration for connection to a fiber optic modem (ONT)
    - The speed of the Ethernet connection between LAN 1/WAN and the upstream device (e.g., fiber optic modem) is displayed on the overview page
    - further improvements and bugfixes
    With each FRITZ!OS update, AVM also updates its security functions. Therefore we recommend performing the update for all devices.
    Below you find a complete list and descriptions of the new functions in the latest FRITZ!OS, along with a list of further improvements in this version.
    # New functions of FRITZ!OS 7.81
    ## DSL:
    - **Fixed** Establishing a VDSL connection took very long or was repeatedly disrupted
    ## Internet:
    - **Fixed** During active VPN connection over WireGuard® with transmission of entire network traffic, the FRITZ!Box allowed selection of user for HTTPS access
    - **Fixed** In certain browser versions https pages were not filtered reliably
    - **Fixed** Incorrect entry for the NTP server in DHCPv6 reply of the FRITZ!Box resulted in IPv6 home network devices not being able to obtain a valid time
    ## Telephony:
    - **Fixed** Telekom CompanyFlex SIP trunking - Outgoing calls failed when telephone number suppressed
    - **Fixed** Under certain conditions, voice transmission was disrupted after a short time during ongoing telephone calls
    - **Improved** The list of voice codecs for telephony was reworked for the provider Telekom
    ## Smart Home:
    - **Fixed** Devices that were registered with the FRITZ!Smart Gateway were not displayed on the user interface of the connected FRITZ!Box
    - **Fixed** Link for automatic adjustment between an external temperature sensor and a radiator control was lost when the FRITZ!Box restarted
    - **Fixed** Status of the FRITZ!DECT 350 was transmitted incorrectly in the Smart Home home network
    - **Fixed** The freely selectable device name for FRITZ!DECT 350 was not adopted
    - **Fixed** Under certain circumstances empty Smart Home pages were displayed in the FRITZ!Box user interface
    ## System:
    - **Fixed** After failed download of a FRITZ!OS update, under certain circumstances no further update queries
    - **Fixed** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, a successfully established internet connection via DOCSIS was sporadically not detected and an incorrect error page was then displayed
    - **Fixed** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, a backup of the FRITZ!Box internal memory unnecessarily included files that were saved on an external USB storage device connected to the FRITZ!Box
    - **Fixed** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, an error occurred if an IPv4 address range other than the preset range was used in the home network
    - **Fixed** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, the IP filter list was not transferred to the new FRITZ!Box
    - **Fixed** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, the settings for DNS rebind protection were not transferred to the new FRITZ!Box
    - **Fixed** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, the "Factory settings" status of the new FRITZ!Box was not always reliably detected and it was not possible to transfer the settings
    - **Improved** When using the "Transfer Your Settings to a New FRITZ!Box" wizard, the settings for the captive portal of a public Wi-Fi hotspot are now transferred to the new FRITZ!Box
    https://download.avm.de/fritzbox/fritzbox-7590-ax/other/fritz.os/info_en.txt
    #32389
    On this page you can find latest FW-releases, sorry only in German, you have to use translator: https://avm.de/service/update-news/neueste-updates-der-fritz-produkte/
    Lab-firmware (beta) can be found here: https://en.avm.de/fritz-lab/fresh-from-development/fresh-from-development/
    #32390
    • Replies 8,748
    Great news and thanks for sharing this link
    #32464
    Successor 7690 is available to buy now (within UK maybe some days or weeks later).
    #32465
    • Replies 8,748
    Great news and good to see the new FRITZ!Box 7690 supporting Wifi 7
    I have created a new dedicated thread for the FRITZ!Box 7690
    AVM FRITZ!Box 7690 – Official Thread
    #33888
    Fritz!OS 8.0 has been released today!
    Other Fritz!Boxes with 7.90 Lab will get it in the next days and weeks.
    • This reply was modified 2 years, 2 months ago by GrisuGrisu.
    #33890
    • Replies 8,748
    Big news that is for Fritz!box community
    It was a shame that an important feature is not to be included in the version for the time being. This is support for the Matter standard. For the time being, this will only be rolled out for the Fritz Smart Gateway. Only later will it come for compatible Fritzbox models.
    #35893
    • Replies 8,748
    Version:        FRITZ!OS 8.02
    Language:       Dutch, English, French, German, Italian, Polish, Spanish
    Release date:   09/01/2025
    **New features:**
    - User interface: Diagram showing the connections in the overview (homepage)
    - New Online Monitor informs about the load on the internet connection and the load by individual network devices
    - Internet: Now IPv6 data can also be transmitted via a WireGuard® VPN tunnel
    - Mesh: Redesigned diagram of all devices connected with the FRITZ!Box with additional functions
    - DECT: The number of DECT telephone calls possible concurrently was increased from three to five
    - Push service: Reworked design and more convenience
