NVMe Drives Hi all, So I’m considering potentially getting a new nvme drive to place in 2nd slot, only issue is it sits right under the gfx card, I thought my new…
› UKTH forums › PC & Laptop Gaming › Gaming Hardware, etc. › NVMe Drives Hi all, So I’m considering potentially getting a new nvme drive to place in 2nd slot, only issue is it sits right under the gfx card, I thought my new...
Viewing 7 posts - 16 through 22 (of 22 total)
  • #29013
    Would 2 be ok too?
    If not, I’ll try to get just 1 – might be easiest option, annoying can’t use onboard but oh well.
    When it comes time to upgrade this current PC, will get a standard ATX board and maybe all nvme ports will have heatsinks on them and be in easy to access locations.
    Just found this, look reasonable?
    Appears to be a newer model but no heatsink with it so figured get the all in one?
    • Replies 8,749
    Alas picture didn’t come through ?
    #29016
    hmm well that’s new…. it wasn’t a picture, it was a URL I pasted…..
    re-trying using the Link button…
    https://www.amazon.co.uk/glotrends-Adapter-Heatsink-2230-2280-PA09-HS/dp/B07FN3YZ8P
    ah that worked BUT if i pasted the link in as text – it didn’t like it… another bug? i was able to copy/paste URLs as text before…
    • Replies 8,749
    Amazon is always tricky with links etc. and I will add it to my list
    price is great for the card, worth a try at that price
    #29023
    Thanks, as long as it will work I’ll bear it in mind.  Ideally I’d like a 4TB NVMe but the WD one is price – similar price to the gfx card… bit steep…
