Speed Issue This issue i have noticed on my friends windows 10 computers, where internet speed looks capped … Symptoms –Ā  – > Recently you have upgraded your internet connection speed from…
› UKTH forums › Computers › Windows (OS) › Speed Issue This issue i have noticed on my friends windows 10 computers, where internet speed looks capped … Symptoms –Ā  – > Recently you have upgraded your internet connection speed from...
  • #3998
    AvatarSH
    • Replies 81
    Symptoms –Ā
    – > Recently you have upgraded your internet connection speed from 150Mbps to 500Mbps connection …….but still getting 150Mbps via Ethernet Cable or Wi-FiĀ  on particular windowsĀ  computer , but all other devices are maxing ISP allocated speed andĀ  ISP tech are unable to resolve your issue
    Things You Have Already Checked –Ā
    1) – LAN Cable ( It’s already CAT5e , CAT6, CAT7 and CAT8 )
    2) – Ethernet Port on modem is capable to handle 1000Mbps+
    3) – Checked LAN and Wi-Fi Adapters ( they are capable of LAN – 1000 Mbps , Wi-Fi – 2×2+ AC,AX adapter ) + Updated Drivers to latest version
    4) –Ā  Reset LAN and Wi-Fi Drivers …. and connect to 5Ghz Wi-Fi ( if testing on Wi-Fi )
    5) – There is no QOS software installed on Computer like ASUS GAME V or Killer Networking Suite
    If everything feels correct ………………and issue still persist
    Solution:-Ā
    1) – Search for Command Prompt
    2) – Right Click and run it as administrator
    3) – Type or PasteĀ  “netsh interface tcp show global”Ā  Ā without quotation mark and press enter
    4) – check what -> Receive Window Auto-Tuning Level <- is set to in result
    > > Auto Tuning level can be set to any of the following values
    A) – disabled: Fix the receive window at its default value.
    B) – highlyrestricted: Allow the receive window to grow beyond its default value, but do so very conservatively.
    C) – restricted: Allow the receive window to grow beyond its default value, but limit such growth in some scenarios.
    D) – normal: Allow the receive window to grow to accommodate almost all scenarios.
    E) – experimental: Allow the receive window to grow to accommodate extreme scenarios.
    5) – This issue occurred when Auto Tuning level is set to disabled
    6) – Default Auto Tuning level is normal .. to set it ……… Type or Paste “netsh interface tcp set global autotuninglevel=normal” without quotation mark in Command Prompt window you opened at step 2 and press enter
    for precaution …reboot and than check speed again
    #4002
    • Replies 8,737
    I assume you are an IT professional (day job) ;-)
