WIFI 7 Hi, See Asus have WIFI 7 now on newer model, when do you expect devices will go WIFI 7? i.e laptops or phones/tablets? Next iteration due this year? Kev
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › WIFI 7 Hi, See Asus have WIFI 7 now on newer model, when do you expect devices will go WIFI 7? i.e laptops or phones/tablets? Next iteration due this year? Kev
Viewing 13 posts - 1 through 13 (of 13 total)
  • #32829
    ASUS BE Range of routers have been around for a couple of months now.
    Routers always seem to be ahead of devices, in terms of wifi standards and speeds etc.
    Samsung Galaxy S23 Ultra and newer support Wifi 7 (when this is enabled by Samsung) and a few higher end gaming laptops  also support Wifi 7
    The iPhone 16 Pro series is tipped to feature Wi-Fi 7 support, once enabled by Apple after some serious testing I assume.
    FWIW: Wifi 7 is an exciting time for wireless standards and wireless speeds.
    • Wi-Fi 6 maximum speed is 9.6 Gbps
    • Wi-Fi 7 maximum speed of 46 Gbps I believe.
    #32853
    Yes, i saw the BE range, quiet pricey tbh, hence wondered if newer apple devices (mac/phone/tablet) would feature them or not yet as I think apple stopped going along with the standards for wifi and did there own?
    Samsung is usually a little quicker than say Apple for adoption of newer wifi standards etc. but by purchasing a Wifi 7 router, you do future proof yourself a little more than say a wifi 6e router in terms of updates etc.
    #32856
    Yes, I guess thought it will be a 2-3 years before it becomes more main stream? I mean WIFI 6e isn’t main stream atm, most stuff is still 2.4/5 atm and then if only supported for 5 years, means not much time before it drops off supported list and no doubt there will be a update to WIFI 7 i.e. 7.1 or 7e etc?
    I think only my recent iPhone and maybe tablet will support WIFI 6, my laptop wont support WIFI 6.
    I think so to, luckily Wifi 7 can be disabled, until more Wifi 7 devices are available if somebody had to purchase a new router tomorrow and was concerned about complications etc.
    #32866
    I dont see a benefit of WiFi 6 or 7 for next 10 years or even more in a house with many homebrewed devices.
    They need WiFi 4 to work, so at least you need it with 2,4GHz for those devices (heatpump control or sensors and arduino/ESP or DTU for solar tracking).
    These divices are often without further support but needed to run aplications and no possibility to change them.
    #32871
    WiFi 6 or 7 speeds are great for moving large file sizes and downloading say movies from your local NAS, but for general usage (home) especially if you are not yet connected to a full fibre ISP, then you cannot fully take advantage of Wifi 6 and 7 potential.
    #32873
    • Replies 94
    The Asus BT10 seems to be going on sale in early August (8th), and will hopefully be a lot cheaper than the BQ16 and BQ16 Pro (and I’m not sure they’re easy to get hold of here anyway – certainly Amazon is quoting a delivery time of up to seven months!).
    https://www.asus.com/uk/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-bt10/
    https://www.scan.co.uk/products/asus-zenwifi-bt10-dual-pack-white-aimesh-8x-antennas-per-unit-mu-mimo-tri-band-10gbe-80211be – £787.99 for a twin pack.
    It would also appear to be closest in look and feel as the XT8 that I currently use. I would like to change purely for better backhaul and doing away with the issues relating to Airport radar signals (I am quite close to Luton airport) that has limited me to 80MHz backhaul for most of my time of ownership.
    Having 160MHz would mean most of my smartphones would connect at 2400Mbps and therefore I’d get closer to the full gigabit speed throughout the house (instead of 850-900 when in the same room, and 500-600 elsewhere). Many of my phones are also Wi-Fi 7 compatible, but I don’t have any computers, tablets, or TVs that do and likely won’t for many years.
    At that price I think I will wait a bit. I’d probably wait for some competition and bite if it gets to nearer £500.
    #32876
    Yes, the 320 MHz Bandwidth will be very beneficial.
    #39799
    Seen some more wifi7 routers now, any further thoughts or still not worth changing yet?
    If your wifi clients support wifi 7, then no harm in upgrading and benefiting from wifi 7, I did read an interesting article the other day about Wifi 8 and its designed for Ultra-High Reliability (UHR) and to mimic wired Ethernet stability.
    https://wifinowglobal.com/uncategorized/off-to-the-races-wi-fi-8-arrives-very-early-with-broadcom-and-tp-link/
    #39841
    • Replies 634
    I have both wifi 6 and wifi 7 devices.  When connecting to the wifi 7 BQ16 routers, I am finding that even my wifi 6 devices have faster speeds than when they were connected to the xt8 wifi 6 routers.
    The prices of wifi 7 routers are still stubbornly high even after 2 years.
