Windows 11 SSD Failure Rumours: What Really Happened The Allegation After installing Windows 11 update KB5063878 (Build 26100.4946), some usersβ€”mostly in Japanβ€”reported that their SSDs: Disappeared from File Explorer and BIOS. Showed up as β€œRAW” partitions. Triggered I/O…
› UKTH forums › πŸ’» Computers › Desktops › Windows 11 SSD Failure Rumours: What Really Happened The Allegation After installing Windows 11 update KB5063878 (Build 26100.4946), some usersβ€”mostly in Japanβ€”reported that their SSDs: Disappeared from File Explorer and BIOS. Showed up as β€œRAW” partitions. Triggered I/O...
  • #39382
    The Allegation
    • After installing Windows 11 update KB5063878 (Build 26100.4946), some usersβ€”mostly in Japanβ€”reported that their SSDs:
      • Disappeared from File Explorer and BIOS.
      • Showed up as β€œRAW” partitions.
      • Triggered I/O errors and system crashes during large game updates like Cyberpunk 2077
    The Theory
    • Β The bug only appeared under very specific conditions:
      • SSD more than 60% full.
      • Continuous write of 50GB+ (e.g., game patching).
      • Possibly triggered by certain controller firmwareβ€”but not limited to Phison
    Microsoft’s Statement
    “After thorough investigation, Microsoft has found no connection between the August 2025 Windows security update and the types of hard drive failures reported on social media”.
    https://windowsforum.com/threads/windows-11-august-2025-patch-kb5063878-not-causing-widespread-ssd-failures.379192/
    #39384
    Even I had this the last days!
    SSD wasnt seen by bios, so couldnt load bootloader.
    I had to switch off power, afterwards I could see it in bios again and change boot partition to my SSD to start windows again.
    I dont game, but SSD is quite full.
    #39385
    Does seem like you maybe also caught by this.
    Your SSD controller may be hitting a firmware deadlock during high I/O or background cleanup. Windows 11’s latest update seems to exacerbate this by:
    • Changing how write queues are flushed.
    • Possibly skipping certain TRIM or flush commands.
    • Overloading the SSD’s internal buffer, especially if it’s already juggling wear-leveling.
    All theory but the drive does disappear from BIOS, good to see you found a workaround in your case.
    #39395
    This time bluescreen after resume from standby, after restart no SSD visible in BIOS to boot from.
    Had again to switch off power manually for a second.
    #39396
    Not good, you should consider Windows Update being rolling back to a previous version until Microsoft release next update and see if this update is the problem Β
