- This topic has 4 replies, 2 voices, and was last updated 5 years, 8 months ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Anyone managed to get 300mbps from BT with DSL-AC88U? Is this modem even compatible with 300mbps g.fast? I’ve tried everything and can’t get my download speed higher than ~140mbps wired. Data rate is showing 329mbps down and 50mbps up...
Is this modem even compatible with 300mbps g.fast? I’ve tried everything and can’t get my download speed higher than ~140mbps wired. Data rate is showing 329mbps down and 50mbps up (the upload speeds I can attain in a speedtest). Any tips for config etc would be appreciated.
[quote quote=12442]Is this modem even compatible with 300mbps g.fast? I’ve tried everything and can’t get my download speed higher than ~140mbps wired. Data rate is showing 329mbps down and 50mbps up (the upload speeds I can attain in a speedtest). Any tips for config etc would be appreciated.[/quote]
I have seen others achieve higher G. fast speeds, alas so many issues with this model, try disabling AiProtection and disable QoS, any chance of showing us your stats page ?
Edit, also make sure you are only using IPv4 as IPV6 does not work to our UK BT standard /56
FYI –https://uktechhub.com/forums/reply/1865/
[quote quote=12445]
FYI –https://uktechhub.com/forums/reply/1865/[/quote]
Looks like it’s back to the smart hub and airport extreme combo for me. Besides speeds, the old openvpn build on this model only supports TLS 1.0 so can’t use it with my provider.
DrayTeK Vigor 166 modem supports G.fast
A Tad pricey – https://draytek.co.uk/products/business/vigor-166
Gave all that a go and got a modest increase, but still around the 150mbps mark. You’re right about this model and issues, none of the features seem to actually work!
https://gyazo.com/8ee13baa0d8e4448e3950554347d6819
https://gyazo.com/2e8c4bc34f6b6979ba2f5c0b4d477d45
https://gyazo.com/f8339962826a640fc9ed27b2514536b6
