ASUS DSL-N16 issue with wifi show me password is incorrect Hello.my asus dsl-n16 has issue with wifi. some times wifi connection drop and i can’t connect to wifi . also i notice that FREE RAM IS ONLY 3 MB!! IS…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-N16 issue with wifi show me password is incorrect Hello.my asus dsl-n16 has issue with wifi. some times wifi connection drop and i can’t connect to wifi . also i notice that FREE RAM IS ONLY 3 MB!! IS...
Viewing 11 posts - 16 through 26 (of 26 total)
  • #4840
    • Replies 8,738
    Hi @kamiboy – I am glad ASUS are looking after you, they (ASUS) did email me to say they contacted you as they wanted more information to help resolve for Memory usage ?
    Let us know how it goes ?
    #4872
    Avatarlostcause
    • Replies 53
    Hello Dear , ASUS contact me and kindly they send me a new beta FW (DSL-N16_9.1.2.3_786-g086cfb6.trx.zip) and i want to share it with you and other people :
    https://www.asuswebstorage.com/navigate/a/#/s/0DFB1D256B9244F88F3B3D7FF3425E16Y
    hopefully it fix wifi and vpn issues.
    DSL-AC51 has the same issues. I reached out to Asus some time ago through the GUI feedback form, but so far no response yet.
    Hopefully they will provide a new FW for the DSL-AC51 as well.
    #4874
    • Replies 8,738
    [quote quote=4838]
    @kamiboy – ASUS have contacted me today regarding DSL-N16 VPN, so I have mentioned you sent them a Feedback form on the 8th, I have also mentioned to ASUS regarding the memory usage causing issues over time, so hopefully they will contact yourself in a day or two
    Hello Dear , ASUS contact me and kindly they send me a new beta FW (DSL-N16_9.1.2.3_786-g086cfb6.trx.zip) and i want to share it with you and other people : https://www.asuswebstorage.com/navigate/a/#/s/0DFB1D256B9244F88F3B3D7FF3425E16Y hopefully it fix wifi and vpn issues.[/quote]
    @kamiboy
    – has the new firmware from ASUS improved RAM usage and VPN issues ?
    @lostcause
    – if @kamiboy new firmware fixed the issues, I will ask ASUS if we can have a fix for the DSL-AC51 and others (MediaTeK based devices)
    #4878
    Avatarlostcause
    • Replies 53
    @lostcause – if @kamiboy new firmware fixed the issues, I will ask ASUS if we can have a fix for the DSL-AC51 and others (MediaTeK based devices)
    Yes hopefully they look into it. Having to reboot the device every week/other week upsets the ISP DLM.
    #4884
    Avatarkamiboy
    • Replies 32
    [quote quote=4874]
    @kamiboy – has the new firmware from ASUS improved RAM usage and VPN issues ? @lostcause – if @kamiboy new firmware fixed the issues, I will ask ASUS if we can have a fix for the DSL-AC51 and others (MediaTeK based devices) [/quote]
    Hello dear, vpn issue is not fix yet although i changed my isp but the issue is not isp it is ASUS router. modem reboot itself when l2tp vpn client is connected.
    for wifi issue and ram issue i need to test more i can’t comment about wifi now.
    #4886
    • Replies 8,738
    @kamiboy – have you managed to feed back to ASUS that VPN does not work for L2TP with new firmware ?
    #4888
    Avatarkamiboy
    • Replies 32
    [quote quote=4886] @kamiboy – have you managed to feed back to ASUS that VPN does not work for L2TP with new firmware ?[/quote]
    today i sent feedback to ASUS again about vpn rebooting issue.
    #4889
    Avatarkamiboy
    • Replies 32
    [quote quote=4888]
    today i sent feedback to ASUS again about vpn rebooting issue.[/quote]
    #4891
    • Replies 8,738
    Thanks for that update, hopefully they (ASUS) can get the L2TP issue fixed ;-)
    #4997
    Avatarkamiboy
    • Replies 32
    [quote quote=4891]Thanks for that update, hopefully they (ASUS) can get the L2TP issue fixed ;-)[/quote]
    update :
    asus found what the issue is … they respond to my last email:
    Regarding the “l2tp vpn rebooting issue” you mentioned, we have found this problem and we are trying to solve it.
    In addition, we have found that it seems that if the client uses Ethernet to connect, this problem will not occur. Only when the connection is made over the wireless network will the reboot occur.
    If you are using a wireless for testing, please help us to switch to a wired network for testing to check if it is as I said.
    i turned off wireless radio and problem solved as ASUS  support said. a fix coming soon.
    #4998
    • Replies 8,738
    @kamiboy – thanks for update and good news ASUS have found the issues, I am sure others are also looking forward to the updates
    Not often we have good news
