› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-N16 issue with wifi show me password is incorrect Hello.my asus dsl-n16 has issue with wifi. some times wifi connection drop and i can’t connect to wifi . also i notice that FREE RAM IS ONLY 3 MB!! IS...
- This topic has 25 replies, 3 voices, and was last updated 7 years ago by
October 12, 2019 at 5:12 pm #4777
Hello.my asus dsl-n16 has issue with wifi. some times wifi connection drop and i can’t connect to wifi . also i notice that FREE RAM IS ONLY 3 MB!! IS IT NORMAL?
October 12, 2019 at 8:05 pm #4783I have seen from other users the DSL-N16 is using a high amount of RAM, I am sure the usage should not be that high, does the RAM usage ever increase to 58MB ?
Wifi password is interesting, is this 2.4Ghz and is this only with certain wifi clients, what length password are you using currently ?
Try changing wifi control channel to 3 or 7 ?
October 12, 2019 at 9:32 pm #4784[quote quote=4783]I have seen from other users the DSL-N16 is using a high amount of RAM, I am sure the usage should not be that high, does the RAM usage ever increase to 58MB ? Wifi password is interesting, is this 2.4Ghz and is this only with certain wifi clients, what length password are you using currently ? Try changing wifi control channel to 3 or 7 ?[/quote]
ram usage increase during times right after reboot free RAM was 22MB.modem uptime was more than 3 days.but you are correct it should not be that high and asus firmware has bug/glitch.
wifi band is 2.4 GHz and all client lost wifi connection and internet connection, also i was not able to open modem setup page (192.168.1.1) via wifi. password length is 13 characters.
i’ll try to change wifi channel and see if problem happen again.
October 12, 2019 at 9:52 pm #4787I am thinking after reboot, everything works as expected, as RAM usage increases, this is when Wifi clients drop and issues with passwords start etc ?
Did this happen with previous firmware’s ?
October 12, 2019 at 11:53 pm #4788[quote quote=4787]I am thinking after reboot, everything works as expected, as RAM usage increases, this is when Wifi clients drop and issues with passwords start etc ? Did this happen with previous firmware’s ?[/quote]
yes sir,after i reboot the router everything works fine and i was able to connect to wifi without any issue.after reboot free RAM was 22MB.i’m not sure the cause of this issue is RAM or something else but it happen randomly and several times with latest firmware.also i feel newer asus firmware is slower than older firmware.it take several seconds to open setup page with new firmware.unfortunatly i didn’t test older firmware but i think older firmware could have same issue with wifi.
October 13, 2019 at 8:18 am #4789October 13, 2019 at 8:34 am #4790Hello.my asus dsl-n16 has issue with wifi. some times wifi connection drop and i can’t connect to wifi . also i notice that FREE RAM IS ONLY 3 MB!! IS IT NORMAL?
Mine does the same, free RAM drops to 4MB.
Usually it runs fine for 1-2weeks, then suddenly you can’t connect through WIFI any more. Turning the radio OFF/ON through the admin page gets it going again.
Also when you have the wireless scheduler enabled, when the wifi radio turns off, it also turns off your LAN.
Mine has been running for 12 days now, with free RAM around 4 MB. Will see how much longer it can go. Firmware Version:v9.1.2.3_783
October 13, 2019 at 9:38 am #4791@lostcause – thanks for the info and good to understand RAM usage effects wifi stability
October 13, 2019 at 4:52 pm #4792[quote quote=4791] @lostcause – thanks for the info and good to understand RAM usage effects wifi stability
[/quote]i sent feedback to ASUS again and said i have spoken with “UK Sentinel”.
October 13, 2019 at 5:58 pm #4793October 14, 2019 at 4:02 am #4794Mine has been running for 12 days now, with free RAM around 4 MB. Will see how much longer it can go. Firmware Version:v9.1.2.3_783
Ok, had to reboot this morning, router became unresponsive, no connection possible, either through WLAN or LAN.
So it lasted a little over 12 days without reboot.- before reboot 3/4MB free RAM
- after reboot 11/12MB free RAM
- router only has 3 phones (2 simultaneously) connecting through WLAN and only 1 PC through LAN
- older firmwares that i tried experience the same issue. (But have not tried all versions)
- System log > General log does not show the most recent entries, only older up to a certain timestamp. This timestamp varies after you hit the refresh button. But it seldom shows the most recent log entry. Sometimes it doesn’t show a log it all. The non beta firmware has this issue as well.
Much more minor bugs in the firmware, but the RAM/Reboot issue and the log entries stand out for me.
October 14, 2019 at 7:16 am #4795October 14, 2019 at 8:00 am #4796[quote quote=4795] @lostcause – I will show ASUS this post and see what they say[/quote]
Thanks, highly appreciated!
Additional info: My router runs almost stock settings and has a light load with only a maximum of 3 devices attached at one time. (2WLAN/1LAN)
I just let it do its job, until it becomes unresponsive.You need to login in order to vote
October 16, 2019 at 4:15 pm #4803October 21, 2019 at 12:40 pm #4838[quote quote=4803] @kamiboy – ASUS have contacted me today regarding DSL-N16 VPN, so I have mentioned you sent them a Feedback form on the 8th, I have also mentioned to ASUS regarding the memory usage causing issues over time, so hopefully they will contact yourself in a day or two
[/quote]Hello Dear , ASUS contact me and kindly they send me a new beta FW (DSL-N16_9.1.2.3_786-g086cfb6.trx.zip) and i want to share it with you and other people :
https://www.asuswebstorage.com/navigate/a/#/s/0DFB1D256B9244F88F3B3D7FF3425E16Y
hopefully it fix wifi and vpn issues.
