ASUS RT-AC86U Hardware Specs he RT-AC86U was released last month in China, it is a dual core 1.8 MHz processor (Broadcom) with 512Mb Ram, It is similar to the GT AC5300 in terms of…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AC86U Hardware Specs he RT-AC86U was released last month in China, it is a dual core 1.8 MHz processor (Broadcom) with 512Mb Ram, It is similar to the GT AC5300 in terms of...
  • #405
    It is similar to the GT AC5300 in terms of hardware, but has only two cores and looks more like the RT-AC68U
    CPU1: Broadcom BCM4906 (1.8 GHz, 2 cores)
    FLA1: 256 MiB (Macronix NAND)
    RAM1: 512 MiB (Micron)
    WI1 chip1: Broadcom BCM4366E
    WI1 802dot11 protocols: an+ac
    WI1 MIMO config: 4×4:4
    WI1 antenna connector: U.FL, RP-SMA
    WI2 chip1: Broadcom BCM4365E
    WI2 802dot11 protocols: bgn
    WI2 MIMO config: 3×3:3
    WI2 antenna connector: RP-SMA
    ETH chip1: Broadcom BCM4906
    Switch: Broadcom BCM4906
    LAN speed: 10/100/1000
    LAN ports: 4
    WAN speed: 10/100/1000
    WAN ports: 1
    UK Sentinel
