- This topic has 0 replies, 1 voice, and was last updated 1 year, 3 months ago by .
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX1800S Firmware version 3.0.0.4.386_69136 New ASUS RT-AX1800S Firmware version 3.0.0.4.386_69136 version 3.0.0.4.386_69136 2025/08/06 This version of firmware is only applicable to RT-AX1800S, please check the model name from the product SN label or...
2025/08/06
This version of firmware is only applicable to RT-AX1800S, please check the model name from the product SN label or box label before utilizing.
Security Enhancements:
System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
