› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX52 Firmware version 3.0.0.4.388_33950 ASUS RT-AX52 Firmware version 3.0.0.4.388_33950 version 3.0.0.4.388_33950 2025/08/25 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment. Security Enhancements: –...
- This topic has 0 replies, 1 voice, and was last updated 1 year, 1 month ago by
- August 26, 2025 at 7:35 am #39340
2025/08/25
– Detailed Audit Trails – Expanded logging within the authentication module.System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client listIn a completely sane world, madness is the only freedom (J.G.Ballard).
