ASUS RT-AX68U Firmware version 3.0.0.4.388_24919 – 2026/10/05 ASUS RT-AX68U Firmware version 3.0.0.4.388_24919 2026/10/05   This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update to…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX68U Firmware version 3.0.0.4.388_24919 – 2026/10/05 ASUS RT-AX68U Firmware version 3.0.0.4.388_24919 2026/10/05   This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update to...
RELEASE
  • #44038
    • Replies 8,737
    2026/10/05
    Security Fixes:
    VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax68u/helpdesk_bios?model2Name=RT-AX68U
