ASUS RT-AXE7800 – Official Thread ASUS RT-AXE7800 Firmware version 3.0.0.4.388_24396 Version 3.0.0.4.388_24396 2023/12/18 New Features: – Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections….
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AXE7800 – Official Thread ASUS RT-AXE7800 Firmware version 3.0.0.4.388_24396 Version 3.0.0.4.388_24396 2023/12/18 New Features: – Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections....
Viewing 12 posts - 1 through 12 (of 12 total)
  • #28519
    • Replies 8,723
    2023/12/18
    New Features:
    – Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    – iPhone&Android 4G/5G Auto Mobile Tethering allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://www.asus.com/support/FAQ/1050074
    – DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    Bug Fixes and Enhancements:
    – Fixed WAN connection issues.
    – Resolved OpenVPN server TAP mode issue.
    – Added MTU setting for WireGuard client.
    – Ensured consistent display of client status on the WireGuard server.
    – Enhanced system stability when accessing the WireGuard server with DMZ enabled.
    – Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    – Fixed connection in load-balance mode when both WANs have static IPs.
    – Resolved USB path display issue in RE Mode.
    – Improved VPN client internet accessibility with AiProtection.
    – Resolved the issue with Traffic Analyzer unable to record data.
    – Improved AiMesh backhaul stability.
    – Added new IPTV profiles, including Celcom, Celcom-TM, and UNIFI-Business+VoIP.
    Security Fixes:
    – Enabled and supported ECDSA certificates for Let’s Encrypt.
    – Upgraded to the latest dropbear version.
    – Fixed a stack overflow vulnerability.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-axe7800/helpdesk_bios?model2Name=RT-AXE7800
    #33836
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_24631
    Version 3.0.0.4.388_24631
    49.38 MB
    2024/02/15
    – Fixed IP display list issue on networkmap.
    – Fixed a GUI bug for WireGuard client profile name.
    – Improved AiMesh system stability.
    – Fixed AiMesh topology UI bugs.
    – Updated UPnP image files.
    Security Fixes
    – Fixed command injection vulnerabilities.
    – Fixed vulnerability in command injection after authentication.
    – Fixed XSS potentially via malformed hostname in DHCP request.
    SHA256: 425aadd5934e0c1a5cddd0062c5ded45a340f49a0d67009c952183d2ef710fac
    #33837
    Blocked
    • Replies 55
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25058
    Version 3.0.0.4.388_25058
    49.58 MB
    2024/08/28
    – Enhanced AiMesh backhaul stability for a more reliable connection.
    – Enabled WireGuard Server clients to access the Samba server.
    – Enhanced WireGuard performance for smoother VPN connections.
    – Optimized memory utilization and resolved occasional server errors when registering DDNS with an app.
    – Fixed an issue where AiMesh node information was not updating correctly in the AiMesh topology.
    – Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
    – Fixed an issue that caused hostname errors in the DDNS service.
    – Resolved IPv6 network service filter issues.
    – Addressed an issue causing HTTPD crashes.
    – Corrected a display issue in the OpenVPN server that prevented IPv6 settings from being shown correctly.
    Security Updates
    – Enhanced the import process for WireGuard client configurations.
    – Enhanced protection against SSH brute force attacks.
    – Strengthened protection for credentials.
    – Applied patches for vulnerabilities CVE-2023-5678 and CVE-2024-0727.
    – Addressed CVE-2023-48795 by updating the dropbear SSH server.
    – Addressed XSS and self-reflected HTML injection
    – Addressed DoS vulnerabilities in the HTTPD and firewall configuration pages.
    – Improved security in OpenVPN custom configuration.
    – Resolved CVE-2020-13848 by updating libupnp to version 1.3.1.
    – Fixed vulnerabilities in the logmessage function (CVE-2023-35086/CVE-2023-35087).
    – Fixed an information disclosure vulnerability.
    – Resolved Client DOM Stored XSS issues.
    SHA256: 04eb4bae12bd4738ee7471b55944b34ff44196b0c0f6adcedd35bb901429dd4e
    #33838
    • Replies 8,723
    Great news that there is a new firmware release for the ASUS RT-AXE7800 – Firmware version 3.0.0.4.388_25058
    #34223
    Blocked
    • Replies 55
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25061
    Version 3.0.0.4.388_25061
    49.59 MB
    2024/09/24
    1.Optimized memory management mechanisms, improving system efficiency and stability.
    2.Strengthened input validation and data processing workflows, further protecting your information security.
    3.Improved web rendering engine, enhancing browsing experience and security.
    4.Enhanced security of system command processing to guard against potential malicious operations.
    5.Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    SHA256: fff8f5df3ab29c276095dcf68cd0b209e948ad4b43347ef76e8d80ea2197a066
    #34226
    • Replies 8,723
    Great news and thank you for letting us know about this new firmware release
    #34771
    Blocked
    • Replies 55
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25127
    Version 3.0.0.4.388_25127
    49.63 MB
    2024/11/06
    SHA256: 223ffa0ff06cbef540effd0edb8ac9f363bfde9154b9280de6470c3ca0355f97
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-axe7800/helpdesk_bios?model2Name=RT-AXE7800
    #35642
    • Replies 8,723
    New ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25137
    Version 3.0.0.4.388_25137
    2025/02/18
    #35806
    • Replies 8,723
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25142
    2025/02/25
    1.Enhanced input parameter handling techniques to improve data processing stability and system security.
    2.Enhance system access control mechanisms.
    #37354
    • Replies 8,723
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25144
    2025/04/28
    • Improved compatibility with certain IoT devices.
    #39110
    • Replies 8,723
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25192
    2025/08/08
    Security Enhancements:
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
    #39868
    • Replies 8,723
    ASUS RT-AXE7800 Firmware version 3.0.0.4.388_25204
    2025/10/16
    – Enhanced system stability.
    – Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
    – Fixed a privilege escalation vector in the IFTTT token exchange mechanism
    – Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
