- This topic has 0 replies, 1 voice, and was last updated 1 year ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS TUF-AX4200 Firmware version 3.0.0.4.388_33950 New ASUS TUF-AX4200 Firmware version 3.0.0.4.388_33950 version 3.0.0.4.388_33950 2025/08/22 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment. Security Enhancements:...
2025/08/22
System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
