ASUS TUF-AX4200 Firmware version 3.0.0.4.388_34156 – 2026/10/02 ASUS TUF-AX4200 Firmware version 3.0.0.4.388_34156 2026/10/02   – This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS TUF-AX4200 Firmware version 3.0.0.4.388_34156 – 2026/10/02 ASUS TUF-AX4200 Firmware version 3.0.0.4.388_34156 2026/10/02   – This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update...
RELEASE
  • #43856
    2026/10/02
    – This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update to continue using it. Please refer to Speedtest Service Announcement for details.
    – Supports Surfshark VPN account login for a smoother user experience. (Supported model only)
    Security Fixes
    – Web management interface: Strengthened data handling for the connected device list and added stricter content checks when importing configuration profiles.
    – Network speed test service: Added allowlist validation for service command parameters, so that only expected values are accepted.
    – Certificate import process: Adjusted file handling and password passing, with stricter parameter validation.
    – Third-party account authorization: Narrowed the recipients of authorization data to better protect authorization information.
    – Web management interface: Adjusted the output handling of feedback content.
    – Notification service: Added identity verification for local connection sources and tightened the related file permission settings.
    – Mobile device connection authorization: Added a device matching check to strengthen the access token issuance process.
    – Device discovery service: Removed a non-essential internal function endpoint to strengthen overall access control.
    – AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.
    – System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
    – Network diagnostic data query: Strengthened value range checks for time interval parameters.
    – Network diagnostic data query: Added allowlist validation for query fields.
    – Internal data query: Improved field matching logic and optimized the memory release process under error conditions.
    – Time synchronization settings: Strengthened parameter validation for the server name.
    – File upload handling: Fixed an issue where certain input formats could cause the web management service to become unresponsive.
    – Wireless channel selection tool: Adjusted the handling of command parameters to prevent unintended command execution.
    – Certificate upload: Added a pre-check of archive contents to prevent files from being written to unintended locations.
    – System configuration file generation: Strengthened parameter content checks to prevent abnormal configuration values from affecting network service settings.
    – VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/tuf-gaming-ax4200/helpdesk_bios?model2Name=TUF-Gaming-AX4200
