- This topic has 0 replies, 1 voice, and was last updated 1 year, 1 month ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BQ16 Pro Firmware version 3.0.0.6.102_36998 New ASUS ZenWiFi BQ16 Pro Firmware version 3.0.0.6.102_36998 version 3.0.0.6.102_36998 2025/08/13 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment....
2025/08/13
Security Enhancements:
System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
