› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58623 – 2026/10/01 ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58623 2026/10/01 This update includes a required change for the Speedtest service. If Speedtest is supported on your model, you must install this update...
- This topic has 0 replies, 1 voice, and was last updated 1 month, 2 weeks ago by
October 1, 2026 at 12:50 pm #43810
2026/10/01
Security Fixes:
AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
AiCloud: Strengthened authentication and path validation for remote file access.
VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.We recommend updating to this version to maintain optimal protection.
