- This topic has 0 replies, 1 voice, and was last updated 1 year, 3 months ago by .
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24753 New ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24753 Version 3.0.0.4.388_24753 50.27 MB 2025/08/04 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security...
50.27 MB
2025/08/04
Security Enhancements:
System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
