› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Asuswrt-Merlin 3006.102.8 has now been released – 08/07/2026
- This topic has 2 replies, 1 voice, and was last updated 4 months ago by
July 8, 2026 at 7:27 pm #42966
Asuswrt‑Merlin 3006.102.8 has been released for supported models, bringing updated GPL merges, improved UPnP compatibility, and enhancements to OpenVPN functionality. Asuswrt-Merlin 3006.xxx Changelog ================================= 3006.102.8 (8-July-2026) - NOTE: There has been important changes to OpenVPN, some necessary with the update to OpenVPN 2.7. Make sure you read the details below, especially if running an OpenVPN server with deprecated features that have now been removed. - NEW: Added tls-crypt V2 authentication support to OpenVPN servers. Don't forget to generate a client key for each client that will connect to you. The keys can be generated from the webui, after you have started the server with TLS control set to "Encrypt Channel V2". A new button will appear that can generate a new client key each time you click on it. - NEW: CSV Import/Export feature on DHCP reservation page (backported from Asuswrt 6.0 to other WIfi 6/7 models). - UPDATED: Merged with GPL 102_37538 (Wifi 6) - UPDATED: Merged with GPL 102_39127 (RT-BE58_Go) - UPDATED: Merged with GPL 102_41424 (GT-BE19000AI) - UPDATED: Merged with GPL 102_39995 (Other wifi 7 models). - UPDATED: OpenVPN to 2.7.5. - UPDATED: OpenSSL to 3.5.7 (GT-BE19000AI) - UPDATED: dropbear to 2026.91. - UPDATED: dnsmasq to 2.93 + some backports. - UPDATED: miniupnpd to 2.3.10-64ef08a. - UPDATED: haveged to 1.9.22. - CHANGED: VPN Status page can now detect running but non-connected WireGuard client tunnels, and report them as being in an error state. - CHANGED: Include two separate miniupnpd builds - with, and without IGDv2 support. Run the appropriate version based on whether the user enables IGDv2 or not. This is to improve compatibility, as IGDv2 support is still problematic for some clients, and cannot be fully disabled at run time. - CHANGED: dhcpc-event script will now be run after the event occured rather than before, allowing it to modify what was applied to the router configuration. - FIXED: Some webui pages may fail to properly show recent changes after clicking on Apply (an outdated cached version would be shown instead). Fixed by disabling ETag support for all .asp files. - FIXED: Cannot disable wifi 6 mode on Wifi 6 models (upstream issue) - FIXED: Multiple CVEs for OpenSSL 1.1: CVE-2026-28387, CVE-2026-28388, CVE-2026-28389, CVE-2026-28390, CVE-2026-7383, CVE-2026-9076, CVE-2026-34180, CVE-2026-42766 and CVE-2026-45447 (backports by RSDNTWK) - FIXED: UPnP port forwards not working if port forwarding or NAT weren't already enabled (patch from Asus) - FIXED: ntpd stops answering after a few days (workaround by restarting it every 24 hours) - FIXED: Connectivity issues when using QoE (GT-BE19000AI, patch from Asus). - FIXED: Client list would redraw every few seconds on Firefox (patch from Asus). - FIXED: If you had a /56 IPv6 prefix, Guest Networks wouldn't allocate a /64 subnet out of it when enabling IPv6 on them. - REMOVED: Support for secret static key authentication from both OpenVPN clients and servers. Deprecated since 2.7.0, and considered outdated in terms of security. - REMOVED: Compression support from OpenVPN server. Update your client configs if you were using it. Client support is still available for backward compatibility with old remote server setups, but expect it to be removed from OpenVPN 2.8. If for some reason you absolutely need it for your server (despite the security implications), you can still enable it through the Custom settings. - REMOVED: Some obsolete/non-working OpenVPN settings such as fast-io (no longer working with 2.7) or data cipher (were replaced with NCP a few years ago). https://www.asuswrt-merlin.net/changelog-3006You need to login in order to vote
July 8, 2026 at 7:28 pm #42967Will be loading this new Asuswrt-Merlin 3006.102.8 release on my RT-BE92U later tonight to see how it handles.
July 9, 2026 at 8:01 pm #42982So dirty flashed my RT-BE92U yesterday evening and so far no issues, the issues I had with printing to my Epson printer via iPhone has been fixed and I can also now edit and change Clients Name which is wasn’t able to do with 3006.102.6.
Edit; Now also seems to be fixed is the issue with wifi devices (apple) connected at range (weak signal) then lose access to the internet for a few seconds at random interviews and then this scenario repeats a few minuites later, especially my iPhone 16 Pro when I’m at one end of the house streaming music etc.
Early days yet, but a positive start.
This reply was modified 4 months ago by
UK Sentinel. Reason: Edit note added
