› UKTH forums › Wireless Routers & Modems › AVM & Wireless › AVM Fritz!OS 7.50 (FW release-cycle MOVE21) First modem got the new firmware version 7.50 just in time for Xmas. Fritz!Box 7590: https://download.avm.de/fritzbox/fritzbox-7590/other/ **New features:** ———————————————————— – FRITZ!OS 7.50 – with over 150 new functions and useful...
- This topic has 77 replies, 2 voices, and was last updated 2 years, 8 months ago by
Grisu.
May 31, 2023 at 5:28 pm #24911
OS 7.55 final released for Fritz!Box 7530: https://download.avm.de/fritzbox/fritzbox-7530/other/
OS 7.55 final released for Fritz!Box 7590: https://download.avm.de/fritzbox/fritzbox-7590/other/# New functions of FRITZ!OS 7.55
## System:
– **NEW** In the new energy-saving mode, Wi-Fi, LAN and USB use even less power for slightly reduced performance
– **NEW** New wizard transfers all important Internet, telephony, and WLAN settings as well as connections to mesh, telephony, and smart home devices to a new FRITZ!Box <for more, see [7]># Further Improvements of FRITZ!OS 7.55
## Internet:
– **Improved** Clarified wording when configuring WireGuard VPN connections
– **Improved** NTP interoperability improved through better estimation of the hardware clock’s deviation
– **Improved** Optimization of bandwidth reservation in the home network through adjustment to transmitted downstream rate
– **Improved** Optimized switching from public DSN servers to provider-side DNS servers
– **Improved** The setting to send all IPv4 data traffic of the FRITZ!Box via the WireGuard VPN connection to (!) a single device is no longer supported
– **Fixed** “Reserve bandwidth in the home network” did not work with IPv6
– **Fixed** During preparation of the first WireGuard connection via remote dial-in the FRITZ!Box ended up in permanent wait mode
– **Fixed** In certain scenarios, switching the type of internet connection led to the WAN interface being switched to LAN
– **Fixed** Interoperability of IPSec VPN connections to LANCOM remote sites including usage of VNC and RDP with active packet acceleration not available
– **Fixed** MyFRITZ! access permission (device sharing) could sometimes only be terminated via IPv4
– **Fixed** Occasionally an IPv6 prefix sharing of a previous “outdated” prefix for a downstream router was not deleted
– **Fixed** On DS Lite connections, switching off IPv6 manually (incorrect configuration) could result in repeated dial-in attempts by the FRITZ!Box
– **Fixed** On TIM connections (Telecom Italia), configuration of a WireGuard connection led to repeated clearing of the internet connection
– **Fixed** Parental controls: Tickets for devices with the standard profile could not be redeemed
– **Fixed** Problems with functionality and/or display of the parental controls in certain application scenarios
– **Fixed** Repeaters sometimes used external NTP servers for initial time determination even if the upstreamFRITZ!Box offered an NTP server
– **Fixed** Under certain circumstances a switch to public DNS servers occurred although the current DNS server could be reached
– **Fixed** Under certain circumstances a switch to public DNS servers took place too early
– **Fixed** VPN: When configuring an IPSec-LAN-LAN connection, the address of the FRITZ!Box was not proposed
– **Fixed** When all IPv4 data traffic was routed over a WireGuard VPN connection, incoming calls were not always signaled
– **Fixed** When packet acceleration was enabled during longer LAN-LAN linkups to CISCO remote sites via IPSec, occasional connection losses occurred## Wi-Fi:
– **Fixed** Mesh Repeater operating mode: The “Select Wi-Fi Network” list did not display invalid Wi-Fi network names (SSID)## Mesh:
– **Fixed** After changing the connection of a repeater, the connection display on the “Home Network > Mesh” page of the user interface was wrong
– **Fixed** When using certain powerline adapters together with a network switch, the connection display on the “Home Network > Mesh” page of the user interface was wrong## Telephony:
– **Improved** Robuster handling of inconsistent data in Apple telephone contacts
– **Improved** Support for using up to 10 individual telephone numbers (MSNs) with the “Telekom CompanyFlex” rate
– **Change** Outdated entries removed from the list of telephone providers## DECT:
– **Improved** Support for DECT headsets from the Sennheiser EPOS series for outgoing calls and picking up calls via the headset button## Home Network:
– **Fixed** Devices with a dot in their name could no longer be renamed
– **Fixed** Display for search for updates for devices in the Mesh was not suitable in certain cases
– **Fixed** Possibly lacking rendering of IP addresses could cause subsequent defects## System:
– **Fixed** “Change notice” push service sent too often information on supposedly new port sharing
– **Fixed** Repeater events were occasionally listed twice in the Event Log
– **Fixed** There were too many events on changed settings in the Event Log## Mobile Network:
– **Improved** Internet connection with username/password supported for Alcatel IK41VE1 IoT/M2M 4G (MBIM) mobile network dongle## USB:
– **Fixed** No network drive function (SMB) could be established to Rclone
– **Fixed** WebDAV online storage could not be used when the country was set to “Spain”————————————————————
May 31, 2023 at 6:34 pm #24914[quote quote=24911]OS 7.55 final released for Fritz!Box 7530: OS 7.55 final released for Fritz!Box 7590:[/quote]
Great news, especially for the 7530 and 7590
June 1, 2023 at 6:39 am #24921June 6, 2023 at 6:17 pm #24965For now there is a small bugfix release for these 2 boxes.
OS 7.56 final released for Fritz!Box 7530: https://download.avm.de/fritzbox/fritzbox-7530/other/
OS 7.56 final released for Fritz!Box 7590: https://download.avm.de/fritzbox/fritzbox-7590/other/# Further Improvements of FRITZ!OS 7.56
## System:
– **Fixed** “Transfer your settings to a new FRITZ!Box” was not visible in fritz.box / WizardsYou need to login in order to vote
June 6, 2023 at 7:34 pm #24966[quote quote=24965]For now there is a small buxfix release for those 2 boxes.[/quote]
June 12, 2023 at 3:19 pm #25177OS 7.56 final released for Fritz!Box 6591-cable: https://download.avm.de/fritzbox/fritzbox-6591-cable/other/fritz.os/
OS 7.56 final released for Fritz!Box 6660-cable: https://download.avm.de/fritzbox/fritzbox-6660-cable/other/fritz.os/
OS 7.56 final released for Fritz!Box 6690-cable: https://download.avm.de/fritzbox/fritzbox-6690-cable/other/fritz.os/You need to login in order to vote
June 12, 2023 at 3:32 pm #25178July 7, 2023 at 6:06 am #25694OS 7.52 initial released for Fritz!SmartGateway: https://download.avm.de/firmware/smartgateway/FRITZ.Smart_Gateway-07.52.image
OS 7.54 final released for Fritz!SmartGateway: https://download.avm.de/fritzwlan/fritzsmart-gateway/deutschland/fritz.os/
OS 7.56 final released for Fritz!Box 7583: https://download.avm.de/fritzbox/fritzbox-7583/other/fritz.os/
OS 7.56 final released for Fritz!Box 7583-VDSL: https://download.avm.de/fritzbox/fritzbox-7583-vdsl/other/fritz.os/
OS 7.56 final released for Fritz!Box 7530-ax: https://download.avm.de/fritzbox/fritzbox-7530-ax/other/fritz.os/
OS 7.56 final released for Fritz!Box 7590-ax: https://download.avm.de/fritzbox/fritzbox-7590-ax/other/fritz.os/
OS 7.56 final released for Fritz!Repeater 1200-ax: https://download.avm.de/fritzwlan/fritzrepeater-1200-ax/other/fritz.os/
OS 7.56 final released for Fritz!Repeater 3000-ax: https://download.avm.de/fritzwlan/fritzrepeater-3000-ax/other/fritz.os/You need to login in order to vote
July 11, 2023 at 5:19 pm #25760OS 7.56 final released for Fritz!Repeater 6000: https://download.avm.de/fritzwlan/fritzrepeater-6000/other/fritz.os/
July 11, 2023 at 5:57 pm #25762OS 7.56 final released for Fritz!Repeater 6000: https://download.avm.de/fritzwlan/fritzrepeater-6000/other/fritz.os/
Great news
July 13, 2023 at 2:11 pm #25797OS 7.56 final released for Fritz!Repeater 1200: https://download.avm.de/fritzwlan/fritzrepeater-1200/other/
OS 7.56 final released for Fritz!Repeater 2400: https://download.avm.de/fritzwlan/fritzrepeater-2400/other/
OS 7.56 final released for Fritz!Repeater 3000: https://download.avm.de/fritzwlan/fritzrepeater-3000/other/
OS 7.56 final released for Fritz!Box 5530-fiber: https://download.avm.de/fritzbox/fritzbox-5530-fiber/other/
OS 7.56 final released for Fritz!Box 5590-fiber: https://download.avm.de/fritzbox/fritzbox-5590-fiber/other/You need to login in order to vote
July 20, 2023 at 9:07 pm #25875OS 7.56 final released for Fritz!Box 4040: https://download.avm.de/fritzbox/fritzbox-4040/other/
OS 7.56 final released for Fritz!Box 4060: https://download.avm.de/fritzbox/fritzbox-4060/other/
OS 7.56 final released for Fritz!Box 6490 cable: https://download.avm.de/fritzbox/fritzbox-6490-cable/other/fritz.os/
OS 7.56 final released for Fritz!Box 6590 cable: https://download.avm.de/fritzbox/fritzbox-6590-cable/other/fritz.os/You need to login in order to vote
July 20, 2023 at 9:33 pm #25877July 25, 2023 at 4:15 pm #26055OS 7.56 final released for Fritz!Repeater 600: https://download.avm.de/fritzwlan/fritzrepeater-600/other/
OS 7.56 final released for Fritz!Repeater 600-v2: https://download.avm.de/fritzwlan/fritzrepeater-600v2/other/
OS 7.56 final released for Fritz!Box 7490: https://download.avm.de/fritzbox/fritzbox-7490/other/7490 is more than 10 years old (published in April 2013) and still got full feature update to same 7.56 level as all the others!
Thats a real huge advantage of their flagship and mainstream products.You need to login in order to vote
July 26, 2023 at 5:41 pm #26084OS 7.56 final released for Fritz!Box 7510: https://download.avm.de/fritzbox/fritzbox-7510/other/
