Brave browser and site Hi, So I’ve tried on and off to access the site but it never let me click any links or login… Today I realised if I turn off the Brave…
› UKTH forums › UKTechHub News & Information › Brave browser and site Hi, So I’ve tried on and off to access the site but it never let me click any links or login… Today I realised if I turn off the Brave...
Viewing 15 posts - 16 through 30 (of 35 total)
  • #42593
    • Replies 8,724
    @Grisu – Thank you for feedback and confirmation Cookie Banner issue is now resolved and Like buttons are working as expected
    @kev2021
    – how the Like button situation today, I restarted the plugin just incase.
    #42594
    • Replies 1,246
    Just wiped brave cache, cookies, re-logged in, turned shields off – no change.  Tried in chrome incognito no change still no like button etc weird…
    Did you try any of my suggestions?
    There is a good reaseon to test it as I think it got to do with your router/DNS restrictions or blockings.
    It doesnt make sense to do the same things again and again hoping it will solve anything.
    • This reply was modified 6 months ago by GrisuGrisu.
    #42597
    • Replies 8,724
    . kev2021 Said:
    Very weird, if you get the chance, as suggested by @Grisu – can you try via your mobile device on data (not wifi) and see if you can see the LIKE and DISLIKE buttons ?
    No need to log-in as Like and Dislike buttons are still visible to guests.
    #42598
    • Replies 1,246
    Works on mobile but not any browser on pc.. very odd…
    • Replies 632
    I had similar issues after changing my DNS from cloudflare to Quad9.  Could not access spedtest.net or load other sites properly on the WiFi on any of my devices including the mobile.  The problem only happened on some sites and not all.
    Then turned off WiFi on the mobile and used mobile data and everything worked fine on the mobile.
    Turned out to be a DNS issue and the only way to fix it was to reset the ISP router and set it up from scratch with Quad9 DNS.  Rebooting or resetting just the BQ16’s did not fix it.
    #42600
    • Replies 8,724
    DNS can be a bit touchy; one little glitch and half the web goes wonky
    @Grisu
    – thanks for suggestion about DNS hopefully this will be @kev2021 issue also
    #42601
    Make a hotspot with your mobile and connect your PC via mobile to the internet.
    Then you see if its belonging to the PC or your router.
    Could be an IPv4/IPv6 problem as well.
    #42603
    • Replies 1,246
    Thanks. Cant connect PC to hotspot as its desktop pc and no wifi.
    hmm strange as vie not updated router or made any changes, maybe isp/dns issue as my router does disconnect and get a new ip etc periodically as I don’t have a fixed ip for internet.
    • Replies 8,724
    When your mobile device worked, was that with home WiFi or cellular data ?
    #42607
    • Replies 8,724
    Also, forgot to mention, what Anti-virus are you using on your desktop and has that changed recently ?
    #42608
    • Replies 8,724
    It is most odd this issue with the forums Like and Dislike buttons, hopefully we can get this resolved
    #42613
    • Replies 1,246
    home AV not changed, no new software installed, no plugins or extension in brave installed, mobile was on WIFI and worked ok. Rather strange.
    • Replies 8,724
    Very, when your next online with that desktop, before you login, check to see if you can see the Like and Dislike icons, this will at least tell me if its your forum user profile ?
    #42618
    You could create a new account here just for testing (deleted afterwards) to see if it got something to do with your recent account.
    And did you test your PC with hotspot from mobile?
