BT OpenReach FTTP Fibre to the Premises availability checker BT OpenReach FTTP Fibre to the Premises availability checker If you enter your details it will be able to check whether FTTP is available in your area, also on the…
› UKTH forums › 📡 Broadband Tech & ISP’s › BT › BT OpenReach FTTP Fibre to the Premises availability checker BT OpenReach FTTP Fibre to the Premises availability checker If you enter your details it will be able to check whether FTTP is available in your area, also on the...
  • #8676
    If you enter your details it will be able to check whether FTTP is available in your area, also on the same page is the option to Sign me Up which will then email you when news of a fibre upgrade is planned etc.
    https://www.openreach.com/fibre-broadband
    #8677
    and the BT Wholesale equivalent for checking FTTP / FTTP On Demand (FTTPoD )and VDSL availability at your premises
    https://www.broadbandchecker.btwholesale.com/#/ADSL
    #8678
    As a very rough guide, FTTPoD – FTTP On Demand costs start from £3000 and add to that a BT Site survey costing around £250
    Cost of  FTTPoD is totally dependent on the location of a nearby FTTC enabled cabinet and length of line etc.
