Car Smart BlueTooth Transmitter Just installed this in my Daughters car, a great little Device that plugs into your cars power socket/Β  lighter socket in that if your car does not support Bluetooth media…
› UKTH forums › Life & Stuff › Cars › Car Smart BlueTooth Transmitter Just installed this in my Daughters car, a great little Device that plugs into your cars power socket/Β  lighter socket in that if your car does not support Bluetooth media...
  • #10785
    • Replies 8,739
    Just installed this in my Daughters car, a great little Device that plugs into your cars power socket/Β  lighter socket in that if your car does not support Bluetooth media (audio) streaming, than this handy little bit of kit basically connects to your mobile media (Bluetooth) device and then transmits the signal via FM so that your streamed music can be played via you car radio.
    Great idea for older cars and only Β£12
    #10788
    Then better invest some bugs more and take one with included DAB+ radio.
    But I can tell you the quality over FM is not as good as with wired connection most radios have through AUX-input on the front.
    I got a receiver from aliexpress for 25-30 € which has these options, you only have to install the sticky antenna in the corner of the front window.
    Some examples for such devices can be found below in #10845: https://uktechhub.com/forums/topic/car-smart-bluetooth-transmitter/#post-10845
    #10789
    • Replies 8,739
    The sound system in the car is not good and to much issues with AUX ports wiring in car being faulty.
    @Grisu
    shopping on Aliexpress, I am surprised
    #10832
    • Replies 8,739
    I always thought you made all your kit from scratch with a soldering iron ( )
    Great links to some alternative products but for my daughter, the FM Transmitter she has is easy to operate and use (Keeps it Simple)
    (FYI – spam filter caught you other posts as to many links) I will adjust it slightly
    #10838
    spam filter option adjustment
    They where only if you are DAB covered and than its fine to update the plain FM-radio to DAB together with BT for mobiles and FM-transmitter.
    #10840
    • Replies 8,739
    Spam filter adjusted, just for you
    #10845
    Did not work, edited my previous posting with https in front of last link and my posting has completely gone again.
    I saved it before so here again:
    Why not aliexpress as many electronics and parts are only available directly from china.
    I have this one: https://aliexpress.com/item/1005001488968696.html
    Now even be found on great river: http://www.amazon.de/Transmitter-Drahtloses-Autoadapter-2-4In-Display-3M-Antenne/dp/B07QKTRJ4L/qid=1609145958
    Similar ones:
    https://aliexpress.com/item/33014863448.html
    https://aliexpress.com/item/32924849691.html
    https://aliexpress.com/item/4000961579435.html
    There might be some more …
    #10852
    • Replies 8,739
    @Grisu – I have emailed you
