Citroen C3 ConnectedCam password So just set up a Citroen C3 ConnectedCam (dashcam) and app and for reference the default password is as below and is given when you use the ConnectedCam app when…
› UKTH forums › Life & Stuff › Cars › Citroen C3 ConnectedCam password So just set up a Citroen C3 ConnectedCam (dashcam) and app and for reference the default password is as below and is given when you use the ConnectedCam app when...
  • #18301
    • Replies 8,736
    So just set up a Citroen C3 ConnectedCam (dashcam) and app and for reference the default password is as below and is given when you use the ConnectedCam app when you connect to the cars ConnectedCam wifi SSID,Β  ‘ConnectedCam’
    PW = ConnectedCAMXXXX (case sensitive)
    Set-Up:
    • Install the ConnectedCam app, sit in the car with the ignition on for the electronics and made sure the camera is on (green light on unit).
    • Open the ConnectedCam app, follow the instructions to connect to the cam’s WiFi and then changed the cam’s WiFi password when prompted (I had to run through this process twice to get the password to change).
    • Connect your phone to the camera’s WiFi ignoring warnings about their being no internet connection.
      Open the ConnectedCam app and it should show you as connected.
    • You can test by pressing the button on the camera to take a picture and watch it appear in the app.
    #18302
    • Replies 8,736
    Great Video showing the ConnectedCAM in action
