Dripping Tap Drip Noise – quick fix Cut a piece of dental floss and wrap one end around the dripping faucet, then lay the rest into the drain. The drips will adhere to the floss and you’ll…
› UKTH forums › Life & Stuff › Home DIY › Dripping Tap Drip Noise – quick fix Cut a piece of dental floss and wrap one end around the dripping faucet, then lay the rest into the drain. The drips will adhere to the floss and you’ll...
  • #12775
    Cut a piece of dental floss and wrap one end around the dripping faucet, then lay the rest into the drain. The drips will adhere to the floss and you’ll be able to get some peace and quiet until a more permanent repair can be made.
